Product
Brand
Synology DS1515 5 Bay Desktop NAS Enclosure - Diskless
Quicklinx: BM33WS00 Mfr#: DS1515
Synology Disk Station DS1515 is the first 5-bay Value series model with a quadcore CPU, hardware encryption engine, four built-in Gigabit LAN ports and the scalability of up to 15 drives, providing the excellent cost-effective storage solution for growing businesses to efficiently manage, protect, and share data.
Synology Disk Station DS1515 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
40 TB
0 (installed) / 5 (max)
24.8 cm x 23.3 cm x 15.7 cm
4.15 kg
1 x 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
30
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
40 TB
24.8 cm
23.3 cm
15.7 cm
4.15 kg
Built-in Devices
Led panel
Processor / Memory
Processors Installed
1 x 1.4 GHz
Number of Cores
Quad-Core
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), print server, High Availability, IP address filtering, web server, backup server, download client, anti-malware protection, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
30
Expansion Bays
5 (total) / 5 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA , 2 x USB 3.0 - Type A
2 x network cable
Wake on LAN, key lock, built-in 2 cooling fans, hardware encryption
RoHS
TAA Compliant
Internal power supply
Software Included
Synology Assistant
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
BM33 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
BM33 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.41
BM33 C2G 2-Port USB 2.0 Manual Switch In Stock £17.67
BM33 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.20
BM33 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
BM33 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.46
BM33 C2G USB 2.0 To Fast Ethernet Adapter In Stock £20.38
