Synology Disk Station DS1515 is the first 5-bay Value series model with a quadcore CPU, hardware encryption engine, four built-in Gigabit LAN ports and the scalability of up to 15 drives, providing the excellent cost-effective storage solution for growing businesses to efficiently manage, protect, and share data.
Optimal price/performance ratio
With its generous hardware specifications, Synology DS1515 is the first Value Series model equipped with a quad-core CPU, 2GB RAM, and four Gigabit LAN Ports. The combination of hard drives and read/write-optimized SSD cache support on DS1515 boosts throughput efficiently while minimizing cost per gigabyte. -
Cross platform file sharing
Synology DS1515 offers comprehensive network protocol support, ensuring seamless file sharing across Windows, Mac, and Linux platforms. Internet file access is simplified by using the web-based file explorer, Synology File Station. HTTPS, firewall, encrypted FTP server, and IP auto-block support ensure file sharing over the Internet is protected at a high security level. For users who are always on the move, Synology provides the convenient app DS file for popular mobile devices such as iPhone, iPad, Android devices, and Windows Phone. Files stored on Synology DS1515 can then be accessed remotely using DS file. -
Unparalleled flexibility
As your data storage needs grow, Synology's DS1515 can grow with you. DS1515 can be connected to dedicated expansion units for additional storage on the fly, growing capacity with minimal effort. When paired with two DX513 expansion units2 through specially designed eSATA connectors, raw capacity can be as high as 90TB. -
24/7 security solution
Synology Surveillance Station offers a centralized interface to manage IP cameras deployed in your office or home, allowing users traveling miles away to safeguard the environment by watching live views, recording events, and taking snapshots with a computer or mobile device. In addition to its intuitive setup and hassle-free interface, Surveillance Station features an optimized live view experience with onscreen operations, smart analytics tools like motion detection, and an alert system that sends instant notification through SMS, e-mail, and DS cam. -
Resilient and reliable
In addition to its superior performance, DS1515 is built for reliability. Four Gigabit LAN ports provide redundancy in the event of unexpected hardware failure while hot swappable drives also help to minimize system downtime during drive replacement. Uninterrupted availability is a critical goal for all businesses; however, many businesses worldwide still remain unprepared for disaster. Synology High Availability (SHA) can ensure a seamless transition between clustered servers in the event of server failure with minimal impact to applications, thus decreasing the risk of unexpected interruptions and costly downtime. -
Easy backup solutions
To protect your valuable data, DS1515 can become a centralized backup destination for consolidating fragmented and unstructured information across your network through a range of options. Advanced backup privilege management makes network backup tasks safer and more efficient. Cloud Station with selective sync and ACL control provides real-time data backup and synchronization among multiple computers and mobile devices. Complete backup solutions including Scheduled LUN Snapshot, LUN clone and Backup & Replication minimize the impact of disasters. -
Energy efficient design
Synology DS1515 is designed with energy efficiency in mind. It is equipped with two 80 x 80 mm fans and a smart airflow design to keep the system running cool 24/7, while its noise dampening design makes it much quieter than PC counterparts. Hard drive hibernation further reduces power consumption and operation costs. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
- Synology Disk Station DS1515 - NAS server - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 40 TB
- Installed Devices / Modules Qty
- 0 (installed) / 5 (max)
- 24.8 cm x 23.3 cm x 15.7 cm
- 4.15 kg ()
- Processor
- 1 x 1.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 30
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 40 TB
- 24.8 cm
- 23.3 cm
- 15.7 cm
- 4.15 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- 1 x 1.4 GHz
- Number of Cores
- Quad-Core
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), print server, High Availability, IP address filtering, web server, backup server, download client, anti-malware protection, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, eMule client, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 30
- Expansion Bays
- 5 (total) / 5 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA , 2 x USB 3.0 - Type A
- Cables Included
- 2 x network cable
- Wake on LAN, key lock, built-in 2 cooling fans, hardware encryption
- RoHS
- TAA Compliant
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- Synology Assistant
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
