Synology DiskStation DS1515+ features a quad core CPU with an AES-NI hardware encryption engine, providing outstanding performance and data encryption acceleration. With four built-in Gigabit LAN ports and scalability of up to 15 drives, Synology DS1515+ is the cost-effective storage solution for centralizing data backups, protecting critical assets and sharing files across different platforms.
Superior performance
Synology DS1515+ is built for speed. With quad core CPU and expandable RAM module, DS1515+ is ideal for the mission critical tasks of small and medium-sized businesses as well as the most intensive applications from data-encryption to virtualization support. Through advanced flash technology, the combination of hard drives and read/ write-optimized SSD cache boosts throughput efficiently while minimizing cost per gigabyte. Powered by its AES-NI hardware encryption engine, DS1515+ also delivers fast encrypted data transmission at over 448.71 MB/s reading and 191.12 MB/s writing. -
Virtualization certified
DS1515+ provides seamless storage solutions for virtualization environments, including VMware, Citrix, and Hyper-V. Being VMware vSphere 5 and VAAI integration certified, DS1515+ helps offload specific storage operations and optimizes computation power for unparalleled performance and efficiency in VMware environments. As the centralized storage of a virtual environment, DS1515+ enables virtual machine migration, allowing movement from server to server whilst eliminating service downtime and disruption to user. Windows Offloaded Data Transfer (ODX) and Synology Advanced LUN support extremely improves the efficiency on massive data transfer and migration. -
Feature-rich business applications
Put your data to work with Synology's DS1515+. With Windows ACL and LDAP support, DS1515+ fits easily into any existing workgroup environment, providing detailed access control and efficient privilege settings. SMB applications including printer sharing, VPN Server, Mail Server, web server, anti-virus, and network video surveillance, allow a single Synology DS1515+ to replace several traditional computing devices and help to maximize your productivity while keeping cost and effort to a minimum. -
Resilient and reliable
In addition to its superior performance, DS1515+ is built for reliability. Four Gigabit LAN ports provide redundancy in the event of unexpected hardware failure while hot swappable drives also help to minimize system downtime during drive replacement. Uninterrupted availability is a critical goal for all businesses; however, many businesses worldwide still remain unprepared for disaster. Synology High Availability (SHA) can ensure a seamless transition between clustered servers in the event of server failure with minimal impact to applications, thus decreasing the risk of unexpected interruptions and costly downtime. -
Unparalleled flexibility
As your data storage needs grow, Synology's DS1515+ can grow with you. DS1515+ can be connected to dedicated expansion units for additional storage on the fly, growing capacity with minimal effort. -
Easy backup solutions
To protect your critical business data, DS1515+ can become a centralized backup target for consolidating fragmented and unstructured information across your network through a range of options. Synology Hybrid RAID allows you to optimize usage and get the most out of your hard drives, while also keeping your storage safe with data redundancy. Complete backup solutions including LUN Snapshot, LUN clone and Backup & Replication minimize the impact of disasters. -
Energy efficient design
Synology DS1515+ is designed with energy efficiency in mind. Equipped with two 80 X 80 mm fans and a smart airflow design to keep the system running cool 24/7, while its noise dampening design makes it much quieter than PC counterparts. Hard drive hibernation further reduces power consumption and operation costs.
- Synology Disk Station DS1515+ - NAS server - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 40 TB
- Installed Devices / Modules Qty
- 0 (installed) / 5 (max)
- 24.8 cm x 23.3 cm x 15.7 cm
- 4.17 kg ()
- Processor
- 1 x Atom C2538 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 40 TB
- 24.8 cm
- 23.3 cm
- 15.7 cm
- 4.17 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, LDAP support, Syslog support, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, ADS, RADIUS support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, eMule client, VPN Server
- DLNA CERTIFIED, UPnP
Security DVR
- 40
- Expansion Bays
- 5 (total) / 5 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA , 4 x USB 3.0 - Type A
- Cables Included
- 2 x network cable
- Hardware encryption
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- Software Included
- Synology Assistant, Synology Data Replicator
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 22.1 dBA
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
