Synology DS114 1 Bay Desktop NAS
Quicklinx: 939RWS00 Mfr#: DS114
Synology® DiskStation DS114 is a feature-rich 1-bay NAS specifically designed to facilitate easy management and storage of digital contents. Running on Synology DiskStation Manager (DSM), DS114 enjoys the full versatility of applications Synology has to offer.
-CPU with Floating-Point Unit Enabling Fast Multimedia Processing
-512MB RAM for Increased Multi-Tasking Power
-Features SuperSpeed USB3.0
-Quiet & Smart Cooling
-Quick & Easy System Installation
-Running on Synology DiskStation Manager (DSM)
  • Optimal price/performance ratio
    Synology DS114 is a compact, all-purpose NAS, designed to fulfill a variety of requirements for small business and home users in single hard drive storage. For a one-bay value model DS114 delivers remarkable read/write performance. The built-in floating-point unit enhances the overall capability of the main CPU, and is particularly advantageous in speeding up thumbnail processing, making photo viewing a refreshing experience. With RAM twice the size of its predecessor, DS114 exhibits a surprising boost in multi-tasking performance. DS114 also comes with two SuperSpeed USB 3.0 interfaces with up to 5 Gbps transmission speed, and an eSATA interface to power an external hard drive. DS114 is extremely versatile in spite of its size. Running on Synology's award-winning DSM operating system, DS114 shares the rich reservoir of applications available in DSM Package Center.
  • Effective backup solutions
    Synology DS114 offers a centralized backup target to consolidate fragmented and unstructured data across a network. A backup wizard is provided for backing up data from Synology DS114 to another Synology NAS, to other resync server, or to an external drive.
  • Cross platform file sharing
    Synology DS114 offers comprehensive network protocol support, assuring seamless file sharing across different platforms. Internet file access is simplified by the encrypted FTP server and the web-based file explorer, Synology File Station. HTTPS, firewall, and IP auto-block support ensure file sharing over the Internet is protected at a high security level.
  • Easy setup and management
    Synology DSM 4.3 operating system offers intuitive and easy-to-use web experience. For users unfamiliar with complicated router configurations or those who simply want to save time, the Synology EZ-Internet Wizard simplifies the process of setting up access to the Synology DS114 from the Internet. EZ-Internet Wizard walks you through all of network settings including firewall, port-forwarding, PPPoE setup and DDNS registration. The multi-tasking web UI on DSM allows users to run multiple applications simultaneously on one tab browser and switch between them instantly.
  • Rich office applications
    The Mail Server package turns Synology DS114 into a dedicated mail service provider, and the USB printer sharing capability minimizes businesses' cost by sharing printing resources throughout the office. VPN Server package offers an easy VPN solution that turns your DS114 into a VPN server, providing a secure way of connecting to a private LAN at a remote location. RADIUS Server strengthens network security by overseeing wireless access authentication via RADIUS (Remote Authentication Dial-In User Service) networking protocol.
  • Energy efficient with cool and quiet design
    All Synology NAS is designed with energy efficiency in mind. Not only does DS114 provide a fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of Wake on LAN/WAN, multiple scheduled power on/off can further reduce power consumption and operation cost. All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Synology Disk Station DS114 - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
4 TB
0
7.1 cm x 22.4 cm x 16.6 cm
710 g ()
1 x 1.2 GHz
Storage Controller
SATA SATA 6Gb/s
Hard Drive
Standard
Network adapter 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
8
RAM
512 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
4 TB
0
7.1 cm
22.4 cm
16.6 cm
710 g ()
Processor / Memory
Processors Installed
1 x 1.2 GHz
RAM
512 MB DDR3
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Hard Drive
Standard - 2.5" / 3.5" shared
Network adapter
Network / Transport Protocol
TCP/IP, PPTP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
8
Expansion Bays
1 (total) / 1 (free) x internal - 2.5" / 3.5"
2 x USB 3.0 - Type A , 1 x eSATA , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Built-in cooling fan, hardware encryption
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
16.25 Watt
Power Provided
48 Watt
TAA Compliant
5 °C
35 °C
5 - 95%
Sound Emission
18 dBA
