Synology DS1019+ 5 Bay NAS - Diskless
Quicklinx: F2M9WS00 Mfr#: DS1019+
  • Celeron
Meet Disk Station, the small footprint, quiet, stylish, and feature-ready server - a great PC server alternative. With additional Windows Active Directory Service (ADS) support, performance and security enhancement, DS-106 is ready to become a Windows 2000 Server companion. It can fit into sophisticated computing environments, yet remain cost-competitive.
Disk Station integrates so many features you could ever think of in a Home & SOHO environment. It shares data, printer, photo, web, multimedia files and more! Having a Disk Station is connecting all your digital contents. It makes sharing everything easy yet controllable.
Creating your own web site is always a fun thing to do. Disk Station now supports PHP+MySQL. You are free to construct your own web site with dynamic web contents, or to install PHP open source applications from the Internet, such as blog and bulletin board. If you are worried about critical data being accessed via Internet, the Secure FTP and Secure Network Backup can take care of it. Secure FTP uses the matured SSL/TLS technology and Secure Network Backup uses the industry-proven SSH package to transfer data.
Data backup is so important but people tend to ignore it, Disk Station makes data backup so complete and automatic that backup always be done without your attention. From Network Backup to Local Backup, from USB Copy to PC Backup (Synology Data Replicator II), you can always find the backup alternatives that fit your needs. Having trouble to share your photos with right persons? Photo Station lets you not only share them with friends through the Internet, but also control who should be able to view which photo albums. You are now the master of your shared photos.
Wouldn't it be cool if you can turn off your PC when you are downloading files? Download Station is just designed for that. You only need to manage the download tasks with Synology Download Redirector, and the files will be transferred to Disk Station. That's it.
  • Versatile storage in a compact desktop chassis
    Capable of transcoding up to 2-channel, 4K video simultaneously, DS1019+ provides a remarkable video streaming experience for advanced home users. Its versatile built-in applications including collaboration, file sharing, data backup and recovery also fulfill SOHO users' various needs, accelerate office productivity, it is even ready for virtualization deployment.
  • A perfect mixture of scalability and performance
    DS1019+ comes with dual native M.2 NVMe SSD slots, allowing you to build NVMe SSD cache without occupying any of the drive trays. You can also scale up to 10 drives with one DX517 expansion unit, seamlessly expanding your storage capacity.
  • 4K multimedia server
    Access and stream your 4K media content anytime and anywhere. DS1019+ supports 4K H.264/H.265 online transcoding via Video Station and DS video, allowing 4K videos to be converted and played on the fly on other computers, smartphones, and media players that originally do not support Ultra HD formats.
Synology Disk Station DS1019+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
70 TB
0 (installed) / 5 (max)
23 cm x 22.3 cm x 16.6 cm
2.54 kg ()
1 x Intel Celeron J3455 1.5 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
40
RAM
8 GB
Storage Operating System
Synology DiskStation Manager
Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
70 TB
23 cm
22.3 cm
16.6 cm
2.54 kg ()
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
2.3 GHz
RAM
8 GB DDR3L
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, FTP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, WOL, download client, event log, ACL support, reset button, surveillance station, DLNA Media Server, 4K resolution support, cloud backup, VPN Server, Link Aggregation, cloud station server, MailPlus server
Encryption Algorithm
SSL, TLS, AES-NI
Security DVR
40
Compression Format
MJPEG, H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
5 (total) / 5 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x M.2 , 2 (total) / 0 (free) x SO-DIMM 204-pin
2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), lockable, built-in 2 cooling fans
Security Slot Type
Kensington security slot
VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
External power adapter
Power Provided
120 watt
Software Included
McAfee AntiVirus (Trial)
Limited warranty - 3 years
5 - 95%
