When performance meets style
DS620slim is a mini 6-bay NAS with a stylish chassis design, perfectly blending in modern workplaces or apartments. Supporting near-instantaneous snapshot technology, DS620slim is an all-around file management solution that fulfills professionals’ needs of advanced data protection.
Remain classic while shrinking footprint
The mini 6-bay design keeps DS620slim classic and saves deployment space. With six 2.5" drive support, DS620slim is able to boost performance by installing SSDs.
The mini 6-bay design keeps DS620slim classic and saves deployment space. With six 2.5" drives support, DS620slim is able to boost performance by installing SSDs. -
SSD cache support
Further enhance storage performance with SSD read/write cache while still having abundant drive bays for data storage. -
Next-generation storage efficiency
Btrfs file system introduces the most advanced storage technologies to meet the management needs of modern large-scale businesses. -
Ultimate file management and sharing
File Station is a web-based, fast and secure management tool built to allow easy, drag-and-drop operations without requiring any complex setup on Mac or PC. Advanced search and filtering tools allow for easy organization and file sharing. -
Synchronize files across your devices
Cloud Station Suite provides real-time data synchronization across all your devices and other Synology NAS. The Intelliversioning feature keeps the most important file versions to better utilize storage space. -
4K Multimedia Server
Access and stream your 4K media content anytime and anywhere. DS620slim supports 4K H.264/H.265 online transcoding via Video Station and DS video, allowing 4K videos to be converted and played on the fly on other computers, smartphones, and media players that originally do not support Ultra HD formats.
- Synology Disk Station DS620slim - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 6 (max)
- 15.1 cm x 17.5 cm x 12.1 cm
- 1.4 kg ()
- Processor
- 1 x Intel Celeron J3355 2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 15.1 cm
- 17.5 cm
- 12.1 cm
- 1.4 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 2.5 GHz
- RAM
- 2 GB (installed) / 6 GB (supported) - DDR3L
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- PPTP, L2TP, FTP, SMB, NFS, HTTPs
- Remote Management Protocol
- SNMP, Telnet, HTTPS, SSH, LDAP
- Network Services Compatibility
- Microsoft Active Directory (AD), Network File System (NFS), FTP, Apple File Protocol (AFP), HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, wake on LAN (WOL), antivirus analysis, High Availability, Access Control List (ACL) support, RADIUS support, SSH support, FTP server, e-mail server, surveillance station, 4K resolution support, VPN Server, SNMP support, Dropbox support, Google Drive support, Microsoft OneDrive support, file station, WebDAV server support, Baidu cloud support, MailPlus server, L2TP support, PPTP server, 4K HD video streaming, built-in H.264 transcoder, built-in H.265 transcoder
- Encryption Algorithm
- SSL, TLS, AES-NI
- Expansion Bays
- 6 (total) / 6 (free) x hot-swap - 2.5"
- 2 x USB 3.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan, Active Directory support
- Security Slot Type
- Kensington security slot
- RoHS
- Power Device
- External power adapter
- Voltage Required
- OS Required
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95%
Synology D3NS1866L-4G RAM Module | In Stock | ÂŁ64.41 |
