Synology DiskStation DS413j 4-Bay NAS Server
Quicklinx: 87HDWS00 Mfr#: DS413j
DiskStation DS413j
Synology® DiskStation DS413j is a budget-friendly 4-bay NAS server for small offices and home use, specifically designed to provide a solution for file storage and sharing with data protection for your home environment with low power consumption, quiet operation and reliability.
Build Your Own Cloud
With Synology DS413j, you can centralize and share up to 16TB of data and files with coworkers and friends. If you find this way of managing files useful, you can have your own cloud by using Cloud Station to access and sync files across different computers. There is no need to configure a router to remote access the DS413j, by using Synology's ezCloud, you can easily extend coverage to the Internet.
Manage your files on your Synology DS413j with File Station which provides easy file navigation on your DiskStation, allowing you to copy, move, delete, rename, upload, or download files without boundaries. If you are always on the move, Synology provides a handy app, DS file for iPhone®, iPad® and Android™ users. Anything stored on Synology DS413j can now be accessed remotely using DS file via the Internet.
Flexible Storage Management
The Synology Hybrid RAID (SHR) automatically builds an optimal RAID volume with data protection based on the hard drives installed, eliminating the need to have hard drives of identical size, while still offering a manual setup option for advanced users.
Multiple Volumes on RAID allows you to create more than one volume on a RAID structure, providing a flexible and efficient way to manage your storage across all available hard drives. When the need arises to expand the volumes, simply allocate more storage space on the UI, and DSM does the rest for you without any service disruption.
Versatile Multimedia Center for Home
With the built-in media server on the DS413j, you can stream digital multimedia content from a Synology DiskStation to a media device such as a stereo system, Sony™ PlayStation® 3 and Microsoft® XBox 360. You can also stream videos and music to a DLNA®/UPnP® compatible TV set so you can enjoy your favorite movies or TV shows that are stored on your DiskStation. Your living room just got better.
For fully digitized music listening experience from the comfort of your couch, by connecting DS413j to a home stereo system and using DS audio App for iPad, iPhone and Android, users can control music playback with simplicity.
Share your Memories to Friends
Photo Station simplifies photo, video, and blog sharing to the public. Features such as theme personalization, blog, and user privilege settings make Photo Station your state-of-the-art lifestyle sharing center on the Internet. Photo Station syncs the album automatically to Facebook, so it is now even more closely intertwined with your social life.
Your 24x7 Download Server
Download Station functions as a 24x7 BT, FTP, HTTP, eMule, and NZB download center without a PC. The eMule & BT search engine allows search-n-download capability without installing additional desktop applications. RSS feed feature will bring the latest updates directly to you. You can subscribe to multiple RSS feeds that list the information of all your favorite downloads, and your download experience is entirely automated.
Back up All Your Important Files
The Synology DS413j offers a centralized backup target to all your PC/Mac® computers in the house. PC Users can back up their data to the Synology DS413j using the free Synology Data Replicator software, while Mac OS X® users enjoy native Apple® Time Machine® integration. A web-based backup wizard is provided for backing up data in the Synology DS413j to another Synology DiskStation or to an external hard drive via USB connection.
Hassle-free System Installation
Web Assistant is a web-based utility to make every DiskStation as easy to install as possible. Installation is done inside your existing web browser by setting up all vital system components in few simple steps. Combined with a quick start widget, users can simultaneously tour the DSM operating system and set it up to use right away.
Peace of Mind with Data Encryption
The Synology DS413j is equipped with an encryption engine which offloads the encryption calculation task away from the main CPU, helping to improve file transfer speeds of the DiskStation. Data protection is an important matter for businesses of all sizes. High-end features previously available only on enterprise level hardware are now accessible via Synology DS413j to small and medium-sized businesses. DS413j provides share-level AES 256-bit encryption to aid in the prevention of unauthorized access attempts to the hard drives.
Energy Efficient with Cool and Quiet Design
Synology DS413j is designed with energy efficiency in mind. Not only does it provide a larger fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet (21.6 dB) compared to PC counterparts. The support of multiple scheduled power on/off and hard drive hibernation can further reduce power consumption and operation cost.
All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Technical Specifications
  • CPU Frequency 1.6GHz
  • Hardware Encryption Engine Yes
  • RAM Size DDR3 512MB
  • Internal HDD/SSD 3.5" or 2.5" SATA(II) X 4 (hard drives not included)
  • Max Internal Capacity 16TB (4X 4TB hard drives) (The actual capacity will differ according to volume types.)
  • External HDD Interface 2X USB 2.0 ports
  • Size (HxWxD) 184mm X 168mm X 230mm
  • Weight 2.23kg
  • LAN 1X Gigabit
  • Noise Level2 21.6 dB(A)
  • AC Input Power Voltage 100V to 240V
  • Power Frequency 50Hz to 60Hz, Single Phase
  • Operating Temperature 5°C to 35°C (40°F to 95°F)
  • Storage Temperature -10°C to 70°C (15°F to 155°F)
  • Relative Humidity 5% to 95%RH
  • Power Consumption3 31.56 W (Access), 7.68 W (HDD Hibernation)
  • Build your own cloud
    With Synology DS413j, you can centralize and share up to 16 TB of data and files with coworkers and friends. If you find this way of managing files useful, you can have your own cloud by using cloud station to access and sync files across different computers. There is no need to configure a router to remote access the DS413j, by using Synology's ezCloud, you can easily extend coverage to the Internet.
  • Flexible storage management
  • Versatile multimedia center for home
    With the built-in media server on the DS413j, you can stream digital multimedia content from a Synology DiskStation to a media device such as a stereo system, Sony PlayStation 3 and Microsoft XBox 360. You can also stream videos and music to a DLNA/UPnP compatible TV set so you can enjoy your favorite movies or TV shows that are stored on your DiskStation. Your living room just got better.
Synology Disk Station DS413j - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
16 TB
0 (installed) / 4 (max)
18.4 cm x 23 cm x 16.8 cm
2.23 kg ()
Danish, Hungarian, Czech, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
1 x 1.6 GHz
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
16 TB
18.4 cm
23 cm
16.8 cm
2.23 kg ()
Processor / Memory
Processors Installed
1 x 1.6 GHz
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - 2.5" / 3.5" shared
Network / Transport Protocol
PPTP, PPPoE, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, print server, IPv6 support, MySQL server, web server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 4 (free) x internal - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Built-in cooling fan, AirPrint, Google Cloud Print
FCC Class B certified, RoHS, BSMI Class B
Mounting kit
TAA Compliant
External power adapter
31.56 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator
TAA Compliant
5 °C
35 °C
5 - 95%
Sound Emission
18.9 dBA
Resources
The following resources are available for the Synology DiskStation DS413j 4-Bay NAS Server
