Synology DiskStation DS213+ 2-Bay NAS Server
Quicklinx: 87HBWS00 Mfr#: DS213+
Synology® DiskStation DS213+ is a high-performance 2-bay all-in-1 NAS server for SMB users. Offering high-performance, energy efficiency, and full list of business features in a network attached storage solution that helps small and medium-sized businesses centralize backup, protect critical assets and share files quickly and efficiently.
Dual Core Performance with Smart Energy Management
With Duo Core processing power, Synology DS213+ delivers an average 81.4 MB/sec writing speed under RAID 1 configuration in a Windows® environment, and 111.2 MB/sec reading1. The built-in Floating-Point Unit makes for faster thumbnail processing to enhance photo viewing at different resolutions. Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS213+ takes less time for data transfer for external hard drives and consumes less power.
Synology DS213+ delivers high performance when needed, but during low activity level it also uses very small amount of power. During System Hibernation mode, DS213+ consumes only 2.6 watts of power to listen for network activities, and resumes back to operation in very short amount of time upon demand. Compared to shutting off the whole system, System Hibernation brings a closer balance between smart energy management and system responsiveness.
Fit to Business Environment
Comprehensive network protocol support assures seamless file sharing across Windows, Mac®, and Linux® platforms. Windows ADS and LDAP integration allows the Synology DS213+ to quickly and easily fit in an existing business network environment with no need to recreate user accounts. Windows ACL support provides much finer-grained access control and efficient privilege settings, allowing users to enjoy native Windows experience. Internet file access is simplified by the encrypted FTP server and the web-based File Station. HTTPS, the built-in firewall, and IP auto-block support ensure file sharing over the Internet is protected at a high security level.
Rich Office Applications
Synology DiskStation DS213+ runs on renowned multitasking operating system, the Synology DiskStation Manager (DSM). Offering a comprehensive list of business applications, the DS213+ can be customized to run multiple applications of your choice to fulfill the requirement of your business environment. The DS213+ replaces several pieces of traditional network hardware with rich features designed specifically for workgroups and offices such as antivirus, video surveillance, webmail, VPN, and LDAP directory services.
Applications are managed in the Package Center, an application portal that hosts applications as ready-to-use packages; to ensure high software integration as well as one-click-installation to eliminate guess work during installation. Additional approved 3rd party PHP web application such as content management, customer relationship management & e-commerce system can be hosted on DS213+ by using Web Station with support for PHP/MySQL® web content.
Effective Backup Solutions
Synology DS213+ offers a centralized backup target to consolidate fragmented and unstructured data across a network. PC users can back up their data to Synology DS213+ using Synology Data Replicator software, and Mac OS X® users enjoy native Apple® Time Machine® integration.
A backup wizard is provided for backing up data from DS213+ to another Synology DiskStation or any rsync server via an encrypted connection, or to an external hard drive via USB 3.0 or eSATA connection. The wizard also makes it easy to back up DiskStation data to the cloud via Amazon S3® or STRATO HiDrive. In addition, users can back up and restore DiskStation shared folders in multiple versions using Synology Time Backup package.
Shared Folder Sync allows users to synchronize a specific folder from Synology DS213+ to another DiskStation- a server-to-client backup mechanism that takes place whenever something is changed on the server side. Users will be able to share documents within their local office seamlessly and safely with encrypted connection. When your DiskStation is down, you will be able to have an immediate backup running in no time.
You can have your own cloud by using Cloud Station to freely access and sync file across different computers. Cloud Station keep multiple versions of a document in case of accidentally delete or upon any change.
Hassle-free System Installation
Web Assistant is a web-based utility to makes every DiskStation as easy to install as possible. Installation is done inside your existing web browser by setting up all vital system components in few simple steps. Combined with a quick start widget, users can simultaneously tour the DSM operating system and setup to use right away.
Peace of Mind with Data Encryption
The Synology DS213+ is equipped with an encryption engine which offloads the encryption calculation task away from the main CPU, helping to improve file transfer speeds of the DiskStation. Data protection is an important matter for businesses of all sizes. High-end features previously available only on enterprise level hardware are now accessible via Synology DS213+ to small and medium-sized businesses. DS213+ provides share-level AES 256-bit encryption to aid in the prevention of unauthorized access attempts to the hard drives.
Energy Efficient with Cool and Quiet Design
Synology DS213+ is designed with energy efficiency in mind. Not only does it provide a 92x92 mm fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of multiple scheduled power on/off and System Hibernation can further reduce power consumption and operation cost.
All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Technical Specifications
  • CPU Frequency 1.067GHz Duo Core
  • Floating Point Yes
  • Hardware Encryption Engine Yes
  • Memory DDR3 512MB
  • Internal HDD/SSD 3.5" or 2.5" SATA(II) X 2 (hard drives not included)
  • Max Internal Capacity 8TB (2X 4TB hard drives) (The actual capacity will differ according to volume types.)
  • Hot Swappable HDD Yes
  • External Storage Interface 1X USB 2.0 port, 2X USB 3.0 ports, 1X eSATA port, 1X SD card slot
  • Size (HxWxD) 165mm X 108mm X 233.2mm
  • Weight 1.25kg
  • LAN 1X Gigabit
  • Wireless Support (wireless dongles not included) Yes
  • Wake on LAN/WAN Yes
  • Noise Level3 19.8 dB(A)
  • AC Input Power Voltage 100V to 240V
  • Power Frequency 50Hz to 60Hz, Single Phase
  • Power Consumption4 22.2 W (Access); 2.64 W (System Hibernation)
  • Operating Temperature 5°C to 35°C (40°F to 95°F)
  • Storage Temperature -10°C to 70°C (15°F to 155°F)
  • Relative Humidity 5% to 95%RH
  • Dual core performance with smart energy management
    The built-in Floating-Point Unit makes for faster thumbnail processing to enhance photo viewing at different resolutions. Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS213+ takes less time for data transfer for external hard drives and consumes less power. Synology DS213+ delivers high performance when needed, but during low activity level it also uses very small amount of power. During system hibernation mode, DS213+ consumes only 2.6 watts of power to listen for network activities, and resumes back to operation in very short amount of time upon demand. Compared to shutting off the whole system, system hibernation brings a closer balance between smart energy management and system responsiveness.
  • Fit to business environment
  • Rich office applications
  • Effective backup solutions
    Synology DS213+ offers a centralized backup target to consolidate fragmented and unstructured data across a network. A backup wizard is provided for backing up data from DS213+ to another Synology DiskStation or any sync server via an encrypted connection, or to an external hard drive via USB 3.0 or eSATA connection. The wizard also makes it easy to back up DiskStation data to the cloud via Amazon S3 or STRATO HiDrive. In addition, users can back up and restore DiskStation shared folders in multiple versions using Synology Time Backup package.
  • Hassle-free system installation
  • Energy efficient with cool and quiet design
    Synology DS213+ is designed with energy efficiency in mind. Not only does it provide a 92 x 92 mm fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of multiple scheduled power on/off and system hibernation can further reduce power consumption and operation cost.
Synology Disk Station DS213+ - NAS server - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Max Supported Capacity
8 TB
2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.25 kg ()
Danish, Hungarian, Czech, Slovenian, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
1 x 1.067 GHz (Dual-Core)
Storage Controller
RAID SATA-300 / eSATA-300 RAID RAID 0, 1, JBOD
Card Reader
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
8 TB
2 (max)
10.8 cm
23.32 cm
16.5 cm
1.25 kg ()
Processor / Memory
Processors Installed
1 x 1.067 GHz
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID - internal
Interface Type
Data Transfer Rate
300 MBps
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Network / Transport Protocol
PPTP, PPPoE, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, SMB, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, print server, IPv6 support, MySQL server, web server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, WebDAV server, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 - Type A , 1 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45 , 1 x eSATA 3Gb/s
1 x network cable
Built-in cooling fan, AirPrint, Google Cloud Print
FCC Class B certified, RoHS, BSMI Class B
Mounting kit
TAA Compliant
External power adapter
22.2 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator
TAA Compliant
5 °C
35 °C
5 - 95% (non-condensing)
Sound Emission
19.9 dBA
Resources
The following resources are available for the Synology DiskStation DS213+ 2-Bay NAS Server
