Synology Diskstation DS1621+ 6 bay
Quicklinx: G12KWS00 Mfr#: DS1621+
Interface: Fast Ethernet, Ethernet, Gigabit Ethernet
Type: 6-Bay
Capacity: 0GB
£783.12 ex VAT
£939.74 inc VAT
Synology DS1621+ is a 6-bay ultra-compact network attached storage solution, ideal to store and protect critical data assets and for users need of high-speed storage in a desktop form factor to turbocharge workflow. It includes M.2 slots for NVMe SSD cache drives, in addition to a PCIe slot for additional network add-in-cards. Highlights include:
  • AMD Ryzen embedded 4-core processor and 4GB DDR4 onboard (expandable up to 32 GB)
  • Expand your storage to a total of 16 bays with DX517 expansion units
  • Built for Private Video Surveillance- 7600 supported cameras, and counting.
  • Boost Performance using M.2 2280 NVMe SSD slots for cache acceleration without using storage drive bays
  • Warranty: 3-year exclusive manufacturer warranty- can be extended to 5 years with EW201
  • Powerful, scalable, and versatile
    Synology DS1621+ is a powerful and compact 6-bay network attached storage solution designed to store and protect critical data assets. Designed for scalability, the DS1621+ enables you to start small and expand as your data grows.
  • Faster than ever
    DS1621+ is faster in just about everything. Get things done quicker and streamline photo management.
  • Turbocharge and expand it
    Upgrade your DS1621+ to match your data requirements, whether it is for faster networking or for higher storage capacity.
  • Ultimate backup solution
    DS1621+ integrates various backup applications into an intuitive user interface, offering durable storage technologies to safeguard your valuable data on any device.
Synology Disk Station DS1621+ - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 6 (max)
28.2 cm x 24.3 cm x 16.6 cm
5.1 kg ()
1 x AMD Ryzen Embedded V1500B 2.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD
10Mb LAN, 100Mb LAN, 1GbE
RAM
4 GB
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
28.2 cm
24.3 cm
16.6 cm
5.1 kg ()
Enclosure Colour
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Network / Transport Protocol
iSCSI
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Hardware encryption, VPN support, WOL, Syslog support, High Availability, download client, file sharing, TFTP support, ACL support, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, WebDAV server, VPN Server, anti-virus protection, Link Aggregation, failover protection, DLNA support, OpenStack compatible, SSD trim, iSCSI LUN clone/snapshot, Windows ODX, cloud station server, MailPlus server, Rsync compatible, Synology Hybrid RAID
DLNA CERTIFIED
Expansion Bays
6 (total) / 6 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 1 (free) x DIMM 288-pin , 2 (total) / 2 (free) x M.2 2280 , 1 (total) / 1 (free) x PCI Express 3.0 x8
3 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA
2 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, Citrix Ready, VMware Ready
Security Slot Type
Kensington security slot
VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM
Accessory pack
Internal power supply
51.22 Watt
Power Consumption Stand by
25.27 Watt
Power Provided
250 Watt
Software Included
McAfee AntiVirus, Synology Central Management System
Limited warranty - 3 years
5 - 95%
Sound Emission
25.2 dBA
Hard Drives
G12K Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £442.11
Type: 6-Bay
Capacity: 0GB
Interface: Ethernet
Interface: Gigabit Ethernet
Brand: Synology
Price Range Ex VAT: £750 - £1000
