Synology Disk Station DS423 - NAS server - 4 bays - SATA 6Gb
Quicklinx: HX6QWS00 Mfr#: DS423
Interface: Fast Ethernet, Ethernet, Gigabit Ethernet
Capacity: 0GB
£314.15 ex VAT
£376.98 inc VAT
Versatile data management platform for work and more.
  • Multi-device access
    Browse, access, edit, and share files securely and conveniently via desktop, mobile, or web browser platforms. Use intuitive admin tools to track and set file permissions and control access to documents, files, and other data.
  • On-demand sync
    Save space on your personal devices by only synchronizing the files you need from your Synology system. Pin frequently accessed files for convenient offline accessibility.
  • Cross-platform sharing
    Build a private data cloud that syncs and shares files swiftly between multiple storage servers, letting everyone access the same set of data at their convenience.
  • Safeguard your data
    Powered by Synology DiskStation Manager (DSM), DS423 utilizes Btrfs, a next-generation file system, to secure data against corruption and allows users to roll back any accidental or malicious changes with instantaneous snapshots.
  • Versatile storage solution for essential needs
    Manage and organize photos efficiently, back up and secure your digital data, and safeguard your physical premises with the DS423.
  • Protect all your data
    Safeguard your digital world and back up all your documents, files, photos, and more with license-free backup solutions.
  • Intuitive video surveillance
    Secure your home or business with a powerful solution to monitor, archive, and analyze footage centrally.
  • Multi-layered backup solutions
    Leverage Synology solutions to back up all data stored on your DS423 onto a secondary server, external storage device, or the cloud.
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 4 (max)
16.8 cm x 23 cm x 18.4 cm
2.21 kg ()
1 x Realtek Semiconductor RTD1619B 1.7 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID JBOD, 0, 1, 5, 6, 10
10Mb LAN, 100Mb LAN, 1GbE
IP Cameras Supported
30
RAM
2 GB
AC 100-240 V (50/60 Hz)
Storage Operating System
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
16.8 cm
23 cm
18.4 cm
2.21 kg ()
Built-in Devices
2 x fans
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB DDR4
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
JBOD, RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Remote Management Protocol
HTTP, HTTPS, SNMP, LDAP
Network Services Compatibility
Server Message Block (SMB), Apple File Protocol (AFP), Network File System v3 (NFS v3), Network File System v4 (NFS v4), Network File System v4.1 (NFS v4.1), Server Message Block 2.0 (SMB 2.0), Server Message Block 3.0 (SMB 3.0), FTP, Calendaring Extensions to WebDAV (CalDAV), Web-based Distributed Authoring and Versioning (WebDAV), Microsoft CIFS
Hardware encryption, Link Aggregation, failover protection, WOL, WOW, SSD trim, Synology Hybrid RAID, RAID migration, NFS Kerberos authentication, Windows ACL, Syslog support, VPN Server, DLNA Media Server
Security DVR
30
Compression Format
H.264, H.265
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160
Expansion Bays
4 (total) / 4 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.2 Gen 1 - Type A , 2 x Ethernet 1000Base-T - RJ-45
2 x network cable
Power recovery, scheduled power on/off, security lock slot (cable lock sold separately)
Security Slot Type
Kensington security slot
FCC, BSMI, VCCI, RCM, UKCA, EAC, CCC, KC, RoHS
Accessory pack, power cable
External power adapter
32.41 Watt
Power Consumption Stand by
4.97 Watt
Power Provided
90 Watt
5 - 95% RH
Sound Emission
20.6 dBA
Interface: Ethernet
Interface: Gigabit Ethernet
Capacity: 0GB
Brand: Synology
