Synology Deep Learning NVR DVA3221 - Standalone NVR - 32 Channels
Quicklinx: G1YMWS00 Mfr#: DVA3221
Capacity: 0GB
Type: 4-Bay
Interface: Ethernet
£2,190.13 ex VAT
£2,628.15 inc VAT
Synology Deep Learning NVR combines powerful video management system features with AI-powered analytics. Generate real-time statistics and alerts to act on issues immediately.
  • Actionable insights
    Video footage is transformed into actionable insights with advanced deep learning-based analytics, enhancing security without requiring additional personnel.
  • On-prem recording and analytics
    Powered by Synology DSM, footage is kept on the device, with options to flexibly backup or archive to other devices and locations.
  • Real-time results
    Instead of post-event analysis, DVA3221 can notify security operators immediately when incidents occur.
  • Comprehensive VMS platform
    DVA3221 is an all-in-one NVR solution, combining video recording, analysis, and advanced video management.
  • Action rules
    Set up security policies so that when a condition is met, corresponding actions can be triggered automatically, reducing time and effort needed for manual interventions.
  • Easy to setup and operate
    Designed to be simple for both administrators and operators, adding and managing cameras, navigating between live feeds and recordings, and configuring permissions and backup tasks are all straightforward. Built on top of Synology DSM, graphical interfaces simplify complicated tasks, while still retaining flexibility.
  • Cross-platform, internet-optional
    Access your surveillance system on any system through a browser, PC/Mac/Linux client, or through mobile apps, both with or without internet access.
  • API ready
    Comprehensive documentation available to third-party developers looking to integrate their products or applications with surveillance station.
  • One-stop support
    An integrated system means a single point of support for the hardware and software solutions, simplifying setup and maintenance efforts needed.
Synology Deep Learning NVR DVA3221 - standalone NVR - 32 channels
NVR - 32 channels - networked
IP Cameras Supported
32
Frame Rate
960 fps
Compression Format
H.264, H.265, MJPEG, MPEG-4, AAC, G.711, G.726, PCM, AMR
Hard Drive(s) Supported
Quantity: 4
Voltage
100 - 240 V
25 cm x 23.7 cm x 16.6 cm
4.92 kg
3 years
NVR
Video Channels
32
32
Compression Format
Package Content
DVR, accessory pack
Network cable - RJ-45 - RJ-45 - 2 pcs.
Software Included (Y)
8 cameras licence
AES, RoHS
Warranty
3 years
Security DVR
Frame Rate (Record)
960 fps
Record Events
Continuous, manual, alarm, motion detection
Networked
People counting, vehicle detection, intrusion detection, key lock, security lock slot (cable lock sold separately), NVIDIA GeForce GTX 1650, RAID 0 support, RAID 1 support, RAID 10 support, RAID 5 support, RAID 6 support, JBOD support, face recognition, Pan/Tilt/Zoom support, mobile phone monitoring, watermark
Hard Drive
Quantity Supported
4
Serial ATA
Removable
Video Server
CPU
Intel Atom C3538
RAM
8 GB
ONVIF compliant
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
SMB, AFP, NFS, Telnet, SSH, SNMP, L2TP, FTP, SSL, TLS, SFTP, HTTPS, NTP, RTSP, TCP/IP, UDP/IP, HTTP
Wake on LAN (WOL), VPN support, LDAP support, Rsync compatible, firewall protection, Access Control List (ACL) support, ONVIF support, e-mail notification, SMS alert
Operating Systems
Windows 7 or later, Mac OS X 10.12 or later
Browser
Internet Explorer/Edge/Safari/Firefox/Google Chrome
Network Port
10/100/1000Base-T x 4
Other Ports
USB 3.2 x 2, eSATA x 2, serial
Voltage
100 - 240 V
Frequency
50/60 Hz
25 cm
23.7 cm
16.6 cm
4.92 kg
5 - 95%
Hard Drives
G1YM Synology HAT5300-12T 12TB 3.5" SATA HDD In Stock £433.72
Capacity: 0GB
Type: 4-Bay
Interface: Ethernet
Brand: Synology
Price Range Ex VAT: £1500+
