Synology DDR4 - module - 4 GB for RS2421+, RS2421RP+, RS2821RP+
Quicklinx: GCFVWS00 Mfr#: D4EU01-4G
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: [N/A]
Data Integrity: ECC
Hurry, only 1 left in stock!
£176.97 ex VAT
£212.36 inc VAT
Increase your Synology NAS performance with this Synology D4EU01-4G 4GB DDR4 ECC UDIMM RAM module.
Built and designed for maximum performance and reliability in Synology devices.
Compatible with:
  • RS2821RP+
  • RS2421RP+
  • RS2421+
  • Enhanced reliability
    Equipped with ECC (Error Correcting Code) to detect and correct internal data corruption, this 4 GB DDR4 SDRAM memory module offers enhanced reliability for your Synology system.
  • Seamless compatibility
    Designed specifically for Synology systems, this DIMM 288-pin memory module ensures seamless compatibility and a straightforward upgrade process, enhancing system performance without the hassle.
  • Optimized performance
    With unbuffered storage, this memory module provides faster data transfer and lower latency, making it ideal for improving the overall performance of your Synology system.
Synology - DDR4 - module - 4 GB - DIMM 288-pin - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Unbuffered
Synology D4EU01-4G
RackStation RS2421+, RS2421RP+, RS2821RP+
4 GB
Upgrade Type
System specific
Synology D4EU01-4G
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
ECC
Unbuffered
Synology RackStation RS2421+, RS2421RP+, RS2821RP+
Type: DDR4 SDRAM
Capacity: 4GB
Speed: [N/A]
Data Integrity: ECC
Registered/Buffered: Unbuffered
CAS Latency: [N/A]
Standard: [N/A]
Brand: Synology
