Synology DDR3L 8GB 2x4GB SO-DIMM
Quicklinx: FDPKWS00 Mfr#: RAM1600DDR3L-4GBX2
Type: DDR3L SDRAM
Capacity: 8GB
Connection: SO-DIMM 204-pin
Speed: 1600MHz
Data Integrity: Non-ECC
£118.57 ex VAT
£142.28 inc VAT
Marketing description is not available.
  • Enhanced compatibility
    Designed specifically for PCs, this memory kit ensures seamless integration with your system, providing a reliable and efficient performance upgrade.
  • Efficient performance
    With a memory speed of 1600 MHz and a low voltage of 1.35 V, this DDR3L SDRAM kit enhances your system's performance while being energy efficient.
  • Easy upgrade
    This system-specific upgrade, featuring two non-ECC, unbuffered SO-DIMM 204-pin modules, simplifies the process of enhancing your PC's memory capacity and performance.
Synology - DDR3L - kit - 8 GB: 2 x 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3L-12800 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
Disk Station DS1517+, DS1817+
8 GB: 2 x 4 GB
Upgrade Type
System specific
DRAM memory kit
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
Synology Disk Station DS1517+, DS1817+
Type: DDR3L SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: [N/A]
Standard: PC3L-12800
Brand: Synology
