Synology DDR3 4GB 1600 MHz/PC3-12800 for Disk Station DS1515+, DS1815+
Quicklinx: BRNQWS00 Mfr#: RAM1600DDR3-4GB
Type: DDR3 SDRAM
Capacity: 4GB
Connection: SO-DIMM 204-pin
Speed: 800MHz
Registered/Buffered: Unbuffered
£74.39 ex VAT
£89.26 inc VAT
RAM capacity can be expanded on some of Synology's business-oriented NAS servers for boosted performance and reliability. DDR RAM modules have been customized for Synology NAS servers to reduce chances of system crash due to compatibility issues. ECC RAM modules are designed for the XS-series and is predominantly used to prevent error strikes introduced during data storage or transmission.
  • Enhanced compatibility
    Designed specifically for PCs, this Synology memory module ensures seamless integration and optimal performance with your system, making it a suitable upgrade choice.
  • Efficient performance
    With a memory speed of 1600 MHz and a CAS Latency of CL11, this DDR3 SDRAM module enhances your system's multitasking capabilities and overall responsiveness.
  • Versatile voltage support
    The module's support for both 1.35 V and 1.5 V supply voltages offers flexibility and compatibility with different systems, ensuring a reliable upgrade without the need for additional adjustments.
Synology - DDR3 - module - 4 GB - SO-DIMM 204-pin / PC3-12800 - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MT/s (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 / 1.5 V
5-year warranty
Disk Station DS1515+, DS1815+, DS2015XS, DS2415+; RackStation RS2416+, RS2416RP+, RS815+, RS815RP+
4 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Voltage
1.35 / 1.5 V
Colour Category
Green
5-year warranty
Synology Disk Station DS1515+, DS1815+, DS2015XS, DS2415+ , Synology RackStation RS2416+, RS2416RP+, RS815+, RS815RP+
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 800MHz
Brand: Synology
