Engineered for top performance and reliability in Synology systems
Unmatched integration with DSM and Synology hardware enable HAS5300 SAS hard drives to reliably deliver class-leading performance in enterprise deployments. HAS5300 drives have passed 200,000 hours of rigorous testing on Synology hardware, feature a 2.5M-hour MTTF, and are covered by Synology’s 5-year limited warranty.
Enhanced reliability
Boasting an impressive MTBF of 2,500,000 hours, this hard drive is designed for sustained reliability and durability, ensuring your data is secure over extensive use. -
High-speed performance
With a data transfer rate of 1.2 GBps and a 7200 rpm spindle speed, this hard drive delivers swift and efficient performance, making it ideal for enterprise environments. -
Optimized for NAS
NAS compatible and engineered to handle a workload of up to 550 TB per year, this hard drive is optimized for 24/7 operation in demanding storage environments.
 - Synology HAS5300 - hard drive - 8 TB - SAS 12Gb/s
 - Hard drive - internal
- Capacity
 - 8 TB
- Form Factor
 - 3.5"
- Interface
 - SAS 12Gb/s
- Data Transfer Rate
 - 1.2 GBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 7200 rpm
 - NAS compatible, Enterprise, workload up to 550 TB per year
 - 101.85 mm x 147 mm x 26.1 mm
 - 770 g
 - 5-year warranty
- Designed For
 - Synology SA3200D, SA3400, SA3600; High Density HD6500; RackStation RS18016xs+, RS18017XS+; Unified Controller UC3200
- Capacity
 - 8 TB
- Form Factor
 - 3.5"
- Interface
 - SAS 12Gb/s
- Buffer Size
 - 256 MB
- Bytes per Sector
 - 512
 - 101.85 mm
 - 147 mm
 - 26.1 mm
 - 770 g
Performance
- Drive Transfer Rate
 - 1.2 GBps (external)
- Internal Data Rate
 - 230 MBps
- Spindle Speed
 - 7200 rpm
Reliability
- MTBF
 - 2,500,000 hours
Expansion & Connectivity
 - 1 x SAS 12 Gb/s
- Compatible Bay
 - 3.5"
- Power Consumption
 - 6.62 Watt (idle) , 9.87 Watt (random read/write)
 - Limited warranty - 5 years
- Designed For
 - Synology SA3200D, SA3400, SA3600 , Synology High Density HD6500 , Synology RackStation RS18016xs+, RS18017XS+ , Synology Unified Controller UC3200
