Synology 8TB HAS5300 3.5" SAS Hard Drive
Quicklinx: GF2CWS00 Mfr#: HAS5300-8T
Form Factor: 3.5
Type: Hard drive
Interface Type: SAS
Capacity: 8TB
Spin Speed (rpm): 7200rpm
18 In Stock
£238.61 ex VAT
£286.33 inc VAT
Engineered for top performance and reliability in Synology systems
Unmatched integration with DSM and Synology hardware enable HAS5300 SAS hard drives to reliably deliver class-leading performance in enterprise deployments. HAS5300 drives have passed 200,000 hours of rigorous testing on Synology hardware, feature a 2.5M-hour MTTF, and are covered by Synology’s 5-year limited warranty.
Synology HAS5300 - hard drive - 8 TB - SAS 12Gb/s
Hard drive - internal
8 TB
3.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
NAS compatible, Enterprise, workload up to 550 TB per year
101.85 mm x 147 mm x 26.1 mm
770 g
5-year warranty
Synology SA3200D, SA3400, SA3600; High Density HD6500; RackStation RS18016xs+, RS18017XS+; Unified Controller UC3200
8 TB
3.5"
SAS 12Gb/s
Buffer Size
256 MB
Bytes per Sector
512
101.85 mm
147 mm
26.1 mm
770 g
Performance
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
230 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
3.5"
Power Consumption
6.62 Watt (idle) , 9.87 Watt (random read/write)
Limited warranty - 5 years
Synology SA3200D, SA3400, SA3600 , Synology High Density HD6500 , Synology RackStation RS18016xs+, RS18017XS+ , Synology Unified Controller UC3200
Form Factor: 3.5
Type: Hard drive
Interface Type: SAS
Capacity: 8TB
Brand: Synology
