RS18016xs+ delivers superior performance at over 3,900 MB/s throughput and 348,000 IOPS under RAID 5 configuration. RS18016xs+ is equipped with 8GB ECC RAM, expandable to 32 GB if needed, so enterprises can guarantee data accuracy, as well as superior performance for the mission-critical tasks of the business.
RS18016xs+ supports a combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS18016xs+ offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant enhancement in server performance.
In addition to the default 4 Gigabit ports, RS18016xs+ includes two PCIe 3.0 x8 slots, allowing installation of two dual-port 10GbE network interface cards for maximized bandwidth, bringing you the superior performance that data-intensive applications demand of your storage system. With native SAS & SATA III 6Gb/s interface support, RS18016xs+ ensures the optimum data process under heavy system loading.
Superior performance
RS18016xs+ delivers superior performance at over 3,900 MB/s throughput and 348,000 IOPS under RAID 5 configuration. RS18016xs+ is equipped with 8GB ECC RAM, expandable to 32 GB if needed, so enterprises can guarantee data accuracy, as well as superior performance for the mission-critical tasks of the business. -
SSD cache technology
RS18016xs+ supports a combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS18016xs+ offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant enhancement in server performance. -
Dual 10GbE NIC and SAS & SATA III 6Gb/s support
In addition to the default 4 Gigabit ports, RS18016xs+ includes two PCIe 3.0 x8 slots, allowing installation of two dual-port 10GbE network interface cards for maximized bandwidth, bringing you the superior performance that data-intensive applications demand of your storage system. With native SAS & SATA III 6Gb/s interface support, RS18016xs+ ensures the optimum data process under heavy system loading. -
Reliable redundancy mechanisms
RS18016xs+ comes with comprehensive redundancy mechanisms to ensure business continuity. Four built-in LAN ports with failover provides the reliable redundancy in the event of unexpected network failure. The high reliability system design including passive cooling technologies prevents single point of failure. Other features such as redundant data paths, power supplies, system fans, and network ports with failover support maximize service uptime. -
Hardware encryption engine for enhanced file transfer speeds
RS18016xs+ is equipped with an encryption engine which offloads encryption calculation tasks away from the main CPU. Thus, the CPU can be free for other important tasks. In addition, Advanced Encryption Standard (AES) on shared folders with hardware acceleration ensures security without compromising access performance, providing over 3,034 MB/s in reading. -
Protection by LUN backup, snapshot, and clone
RS18016xs+ enhances the ease of moving and copying data in a virtualized environment with the features - LUN Backup, LUN Snapshot, and LUN Clone. RS18016xs+ offers iSCSI LUN backup at storage level without extra charge. Synology LUN Clone and LUN Snapshot only take up 1/1000 of the original size which highly optimizes storage usage. In addition, Synology's LUN Snapshot lets you create up 256 snapshots per LUN using point-in-time technology without having any impact on system performance. With better support to servers under VMware vSphere or Windows environment, IT managers can expect guaranteed VM status and data consistency through application-consistent snapshots.
- Synology RackStation RS18016xs+ - NAS server - 72 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 72 TB
- Max Supported Capacity
- 96 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 43 cm x 69.2 cm x 8.8 cm
- 14.5 kg ()
- Processor
- 1 x Intel Xeon E3-1230V2 3.3 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s / SAS RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 12 x 6 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 90
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 5-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 72 TB
- 96 TB
- 43 cm
- 69.2 cm
- 8.8 cm
- 14.5 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 6 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- PPTP, L2TP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, SSH
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), antivirus analysis, IP address filtering, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, iTunes server, DHCP server, FTP server, e-mail server, surveillance station, DLNA Media Server, VPN Server
- Encryption Algorithm
- AES, SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 90
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 4 (total) / 2 (free) x DIMM 240-pin , 2 x PCI Express 3.0 x8
- 2 x USB 2.0 - Type A , 2 x SAS , 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial RS-232 (management) - DB-9
- Built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- TAA Compliant
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 106.54 Watt
- Power Provided
- 500 Watt
- OS Required
- TAA Compliant
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 45.1 dBA
