Synology 6TB (2 x 3TB WD Red) DS213J 2-Bay Desktop NAS
Quicklinx: 8PP2WS00 Mfr#: DS213J/6TB-RED
Synology DiskStation DS213j is a budget-friendly 2-bay NAS server for small offices and home use, specifically designed to provide a solution for file storage and sharing with data protection for your home environment with low power consumption, quiet operation and reliability. Running on DiskStation Manager (DSM) operating system, it delivers ease of use and variety of features.
  • Efficient storage management
    The Synology Disk Station DS213J offers flexible storage options with support for RAID 0, RAID 1, and JBOD configurations, allowing users to optimize data protection and performance according to their needs.
  • Comprehensive network compatibility
    With support for a wide range of network protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, alongside DDNS, FTP, PPPoE, TCP/IP, and iSCSI, this NAS server ensures seamless integration into virtually any network environment.
  • Versatile server capabilities
    This device goes beyond simple storage with features like a backup server, download client, email server, iTunes server, print server, and surveillance station, making it a multifunctional solution for home or office.
  • Advanced security features
    Equipped with SSL and TLS encryption algorithms, alongside firewall protection and Access Control List (ACL) support, the DS213J provides a secure data storage and transmission environment.
  • Energy-efficient operation
    With a power consumption of only 19.82 watts during operation and features like wake on LAN, the Synology Disk Station DS213J is designed for energy-efficient performance without sacrificing functionality.
Synology Disk Station DS213J - NAS server - 6 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
6 TB
Max Supported Capacity
8 TB
2 (installed) / 2 (max)
10 cm x 22.55 cm x 16.5 cm
1 x 1.2 GHz
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 3 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
5
RAM
512 MB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
6 TB
8 TB
10 cm
22.55 cm
16.5 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
1 x 1.2 GHz
RAM
512 MB DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 3 TB
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Network / Transport Protocol
TCP/IP, PPTP, PPPoE, iSCSI, FTP, DHCP, DNS, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, VLAN support, Syslog support, print server, IPv6 support, backup server, download client, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, SMS alert, e-mail server, surveillance station, DNS server, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED
Security DVR
5
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
19.82 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator
TAA Compliant
15 °C
35 °C
5 - 95%
Sound Emission
17 dBA
