Synology ECC RAM module is designed especially for Synology XS-series to expand memory capacity. ECC RAM is predominantly used in servers to combat against the likelihood of errors strikes introduced during data storage or transmission.
Enhanced reliability
Equipped with ECC (Error-Correcting Code) to detect and correct internal data corruption, this Synology 2GB DDR3 SDRAM memory module offers enhanced reliability for your PC, ensuring smoother and more stable performance. -
Seamless compatibility
Designed specifically for system upgrades, this memory module is compatible with PCs that require DIMM 240-pin form factor, making it a perfect fit for your system-specific upgrade needs. -
Effortless upgrade
With a total quantity of 1 slot required and easy installation, upgrading your system's memory has never been simpler. This DRAM module ensures your PC runs faster and more efficiently, allowing for improved multitasking and application performance.
- Synology - DDR3 - module - 2 GB - DIMM 240-pin
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Designed For
- Disk Station DS3611xs, DS3612xs; RackStation RS3411RPXS, RS3411XS, RS3412RPxs, RS3412xs
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- ECC
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Synology Disk Station DS3611xs, DS3612xs , Synology RackStation RS3411RPXS, RS3411XS, RS3412RPxs, RS3412xs
