Synology 16GB DDR4-2400 ECC unbuffered DIMM 288pin 1.2V
Quicklinx: FF7CWS00 Mfr#: D4EC-2400-16G
Get superior performance and reliability from your server with Synology D4EC-2400-16G server memory. This top-of-the-line RAM module is engineered to elevate server performance with the latest DDR4 SDRAM standard.
Built for high-performance server applications, it offers enhanced bandwidth and increased power efficiency for heavy workloads in data centers and beyond. It operates at a speed of up to 2400 MHz speed, delivering fast response time even when handling complex tasks.
With a capacity of 16 GB, this RAM module can handle even the most demanding tasks. Advanced error checking features support ECC error checking to ensure data integrity and reduce the risk of data loss in high-stress environments. Operating at a voltage of 1.2 V DC, it helps conserve power and reduce environmental impact.
And with 288 pins, installation and configuration are easy and straightforward. The support for CL17 CAS latency and Dual rank make this memory module flexible and scalable for any environment. Get the performance you need today with Synology D4EC-2400-16G server memory
  • Enhanced reliability
    Equipped with ECC (Error Correcting Code) to detect and correct data corruption, ensuring high reliability and stability for critical systems.
  • Optimized compatibility
    Designed specifically for Synology systems, this memory module offers seamless compatibility and optimal performance, making it an ideal upgrade choice.
  • High-speed performance
    With a memory speed of 2400 MHz and compliance with PC4-19200 specifications, this DDR4 SDRAM module enhances system responsiveness and multitask capabilities.
Synology - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Unbuffered
Voltage
1.2 V
RackStation RS1619xs+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS4017XS+
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
ECC
Unbuffered
Voltage
1.2 V
Synology RackStation RS1619xs+, RS2418+, RS2418RP+, RS2818RP+, RS3617RPxs, RS3617xs+, RS3618XS, RS4017XS+
