The Synology HAS5300-12T 12TB SAS Hard Drive for NAS is designed to tackle demanding, high-volume workloads. Optimised specifically for Synology storage solutions, its design enables high sequential throughput, maximising the number of concurrent clients the system can sustain. The HAS5300-12T drive is engineered for maximum dependability, passing over 200,000 hours of validation.
Enterprise Reliability and Durability -
For demanding 24/7 environments, rated for 2.5 million hours MTTF and up to 550 TB per year workloads.
Persistent Write Cache Technology -
Minimises the chance of data corruption in the event of sudden power loss.
One-stop Update -
Get automatic firmware updates together through DSM updates, reducing the need for additional maintenance sessions.
For Synology, by Synology -
Stringent validation and up to 200,000 hours of tests ensures maximum reliability in Synology systems.
Enhanced reliability
Boasting an impressive MTBF of 2,500,000 hours, this hard drive is designed for sustained reliability and durability, ensuring your data is secure over extensive use. -
High-speed performance
With a data transfer rate of 1.2 GBps and a 7200 rpm spindle speed, this hard drive delivers swift and efficient performance, making it ideal for enterprise environments. -
Optimized for NAS
NAS compatible and engineered to handle a workload of up to 550 TB per year, this hard drive is optimized for 24/7 operation in demanding storage environments.
 - Synology HAS5300 - hard drive - 12 TB - SAS 12Gb/s
 - Hard drive - internal
- Capacity
 - 12 TB
- Form Factor
 - 3.5"
- Interface
 - SAS 12Gb/s
- Data Transfer Rate
 - 1.2 GBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 7200 rpm
 - NAS compatible, Enterprise, workload up to 550 TB per year
 - 101.85 mm x 147 mm x 26.1 mm
 - 720 g
 - 5-year warranty
- Designed For
 - Synology SA3200D, SA3400, SA3600; High Density HD6500; RackStation RS18016xs+, RS18017XS+; Unified Controller UC3200
- Capacity
 - 12 TB
- Form Factor
 - 3.5"
- Interface
 - SAS 12Gb/s
- Buffer Size
 - 256 MB
- Bytes per Sector
 - 512
 - 101.85 mm
 - 147 mm
 - 26.1 mm
 - 720 g
Performance
- Drive Transfer Rate
 - 1.2 GBps (external)
- Internal Data Rate
 - 242 MBps
- Spindle Speed
 - 7200 rpm
Reliability
- MTBF
 - 2,500,000 hours
Expansion & Connectivity
 - 1 x SAS 12 Gb/s
- Compatible Bay
 - 3.5"
- Power Consumption
 - 4.36 Watt (idle) , 7.8 Watt (random read/write)
 - Limited warranty - 5 years
- Designed For
 - Synology SA3200D, SA3400, SA3600 , Synology High Density HD6500 , Synology RackStation RS18016xs+, RS18017XS+ , Synology Unified Controller UC3200
