Synology 1.92TB SAT5200 SATA 6Gb/s 2.5" SSD
Quicklinx: FW6LWS00 Mfr#: SAT5200-1920G
Synology SAT5200 SATA SSD offers stable I/O performance while reducing the latency of critical services and applications. It is built to handle mixed and intensive 24/7 workloads without compromising on endurance, providing a streamlined storage experience on Synology systems with minimal service disruptions.
Designed for use in Synology systems only, warranty claims will be rejected when used in non-Synology devices
  • Stable high performance for demanding environments
    Engineered for demanding environments such as online transaction processing (OLTP) databases and virtualization deployments, Synology SAT5200 delivers stable high performance, allowing firms to modernize existing storage infrastructure effortlessly.
  • End-to-end data protection
    Safeguards data integrity and consistency over the entire data transfer path.
  • Power loss protection circuit design
    Dedicated capacitors provide sufficient power to flush data-in-flight into NAND flash during a power loss event, further preventing data corruption.
  • Timely notifications
    Plan further ahead for uninterrupted system performance and longevity with timely notifications.
  • Optimal use
    Easy monitoring allows you to make optimal use of each SSD.
Synology SAT5200-1920G - SSD - 1.92 TB - SATA 6Gb/s
Solid state drive - internal
1.92 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
End-to-end data protection, Power Loss Protection (PLP)
69.85 mm x 100 mm x 7 mm
5-year warranty
1.92 TB
2.5"
SATA 6Gb/s
69.85 mm
100 mm
7 mm
Performance
Drive Writes Per Day (DWPD)
1.3
SSD Endurance
4581 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 530 MBps (write)
Maximum 4KB Random Write
60000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
1,500,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
Compatible Bay
2.5"
Power Consumption
3.1 Watt (read) , 5.1 Watt (write) , 1.6 Watt (idle)
VCCI, BSMI, FCC, RoHS, KC, RCM
Limited warranty - 5 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
