Sweex Internal Card Reader All-in-1 USB 2.0 Black - OEM
Quicklinx: 85PQWS00 Mfr#: CR005V3-OEM
Do you want to quickly view your digital pictures or any other data on your memory card? With Sweex Card Readers you can read and write effortlessly onto all types of memory cards. If you choose an internal model card reader, everything is possible in no time!
Sweex Internal Card Reader All-in-1 USB 2.0 - card reader - USB 2.0
Card reader - internal - all-in-1
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, miniSD, RS-MMC, TransFlash, microSD, SDHC Memory Card, miniSDHC, microSDHC
Host Interface
USB 2.0
Required Bay
3.5" internal
3-year warranty
Host Interface
USB 2.0
Required Bay
3.5" internal
Memory Card
(max)
Additional Ports
1 - USB 2.0 - 4 pin USB Type A
Required Ports
1 x 10 PIN IDC
Microsoft Windows Vista / 2000 / XP
USB cable
Software Included
Driver
Plug and Play
Limited warranty - 3 years
