Swann Communications PRO-1080FLD Wide Angle Bullet Camera 1080p
Quicklinx: CMW1WS00 Mfr#: SWPRO-1080FLD-UK
  • Seeing is believing with 1080p (2.1 Megapixels) HD perfect for close up detail such as license plates, faces, clothing colors & more
  • See a wider field of view over a shorter distance with the powerful fixed 3.6mm lens
  • Latest infrared cut filter & LEDs produce amazing night vision clarity in low light to 65ft /20m, with sturdy aluminum camera construction to suit indoor & outdoor applications with IP66 rating for any weather conditions
  • Camera features a built-in microphone so you can see & hear what’s happening and longer 100ft/30m cable offers more options when choosing a mounting location for the camera
  • Use the On-Screen Display (OSD) controller & built-in software to customize the camera settings including color, brightness & wide dynamic range for the best video quality every time
  • This camera can be used in combination with other analog HD surveillance technology including AHD, TVI, CVI from Swann & other brands. It’s the perfect addition if you already have a recording solution (DVR) & need extra cameras
  • A compact dome surveillance camera that’s small in size yet has powerful features & it’s perfect for discreet surveillance in wide areas such as offices, entrances, reception areas, living rooms, yards & more
  • Small yet powerful
    This tiny camera has a diameter of less than 3" (7 cm) and is packed with the advanced features from its bigger sisters. The small dimensions are ideal for those wanting to add a discreet security camera that easily blends in into its surroundings without drawing much attention to it.
  • Weatherproof cameras built for any climate
    Swann cameras can be mounted indoors and outdoors and are built tough to withstand whatever the weather throws at them: rain, snow, dust and hot days. With IP66 weatherproof rating and cables are threaded through the stand so you can rely on their performance, day in, day out.
  • See everything day or night
    No matter if it's day or night, you'll be able to see everything up to 65ft (20m) with the powerful infrared Night Vision. At nightfall, the cameras automatically switch to Night Vision and record in black and white.
  • Built-in microphone adds audio monitoring
    Audio capture adds yet another valuable layer of evidence to your video surveillance for you to hear it live or during playback. Audio could possibly lead to further identification, such as distinguishing someone's voice, as well hear break-in noises and making sure your kids or elderly family members are being well taken care of by anyone assisting them.
  • Long cable for reaching more distant mounting locations
    This camera comes with a 100ft (30m) BNC cable. The long cable will allow you to mount the camera farther away from the DVR, such as at a gate after a long lawn or at large retail spaces.
  • Wide compatibility
    For those techie ones out there, this camera has ample compatibility with a wide range of DVRs and can be used in combination with other analog surveillance technology including 960H, AHD, TVI, CVI from Swann & other brands by using the switch embedded on the camera's cable.
Swann PRO SERIES PRO-1080FLD - surveillance camera - dome
Surveillance camera - fixed - dome - outdoor - weatherproof
Audio
Yes: built-in microphone
6.9 cm x 6.9 cm x 5.5 cm
195 g
White
Wired
Camera
Colour - Day&Night
Video Modes
1080p
Optical Sensor Type
2.1 MP
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Composite video, HD-CVI, HD-TVI, AHD
1 - BNC cable - external - 30 m
Brightness control, Wide Dynamic Range (WDR), infrared cut filter, On Screen Display
Environmental Parameters (operating)
-20 °C - 50 °C
Surveillance camera
Audio Support
Dome
Wired
6.9 cm
6.9 cm
5.5 cm
195 g
United Kingdom
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Video Modes
1080p
Infrared LEDs
12
Infrared Distance
20 m
Image Sensor
2.1 MP
Lens Construction
Fixed focal
Focal Length
3.6 mm
Horizontal Field of View (degree)
90
Video
Mounting kit, security stickers
1 x BNC cable - external - 30 m
IP66
White
Power adapter - external
-20 °C
50 °C
