- State-of-the-art PTZ Dome Camera technology with 4x zoom high resolution up to 3MP HD video image sensor & smart programming
- Awesome 165ft/50m night vision with powerful "array" LEDs so you can see what’s happening 24/7
- Ready to go with flexible mounting options to fix to your wall or ceiling. Installation accessories & cable included
- Includes Cat 5E Ethernet & power cable, connectors & everything needed for HD security made easy
- No more ‘blind-spots’ as the Dome Camera rotates 360 degrees
- Amazing zoom capabilities with 4x (2.8–12mm) optical zoom ensures you can see fine details such as people’s faces & license plates
- Focus on the key locations with multiple preset viewing points
- Smartphone viewing* & controls when combined with a Swann NVR* & free SwannView Link app
- This camera can only be used in combination with Swann’s 1080p & 3MP Network Video Recorders including 7285™ or 7300™ series for cutting-edge IP surveillance in full HD
- Swann NHD-817 - network surveillance camera
- Network surveillance camera - pan / tilt / zoom - outdoor - weatherproof
- Camera Mount Type
- Wall mount, ceiling mount
- 13.6 cm x 13.6 cm x 20.1 cm
- Connectivity Technology
- Wired
- Camera
- Colour - Day&Night
- Optical Zoom
- 4 x
- Video Modes
- 1080p
- Optical Sensor Type
- 3 MP
- Focal Length Control
- Motorized zoom
- Focal Length
- 2.8 mm - 12 mm
- Cables Included
- 1 - network cable - external - 30 m
- Voltage
- DC 48 V / PoE
- Manual white balance, Backlight Compensation (BLC), manual gain control, auto gain control, auto white balance
- Environmental Parameters (operating)
- -20 °C - 50 °C
- Camera Mount Type
- Wired
- 13.6 cm
- 13.6 cm
- 20.1 cm
- Localisation
- United Kingdom
Camera
- Colour - Day&Night - pan / tilt / zoom - outdoor - weatherproof
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 6 m
Image Sensor
- 3 MP
Lens Construction
- Motorized zoom
- Optical Zoom
- 4 x
- Focal Length
- 2.8 mm - 12 mm
- Horizontal Field of View (degree)
- 28 - 91
- Ports
- LAN/power - RJ-45
- Included Accessories
- Ceiling mount kits, wall mount kit, 4 theft deterrent stickers
- Cables Included
- 1 x network cable - external - 30 m
- IP66
- Power Requirements
- DC 48 V / PoE
- Power Device
- Power adapter - external
- -20 °C
- 50 °C
