Swann Communications 8 Channel DVR 1080p
Quicklinx: CMVHWS00 Mfr#: SWDVR-84550H-UK
  • A state of the art & expandable surveillance system with 1080p HD resolution
  • Set & forget by recording from 8 cameras for 160 days+ onto a 2TB hard drive
  • Just add Swann’s PRO-H855™, H856™ & T800™ series cameras & enjoy High Definition recording & playback
  • Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
  • View live or playback video in high definition on your HDTV, LCD screen or monitor via HDMI connection or VGA port
  • Connect in minutes using SwannLink ‘Peer-to-Peer’ easy network connection software
  • Surveillance in the palm of your hand with live viewing on 3G/4G-enabled Smartphone & tablets including iPhone, iPad, Android devices and more using the free SwannView Link app
Swann DVR8-4550 - standalone DVR - 8 channels
Standalone DVR - 8 channels - networked
Image Resolution
1920x1080
Hard Drive
1 x 2 TB
Hard Drive(s) Supported
Total capacity: 4 TB
21.5 cm x 21.5 cm x 4.5 cm
Country Kits
United Kingdom
Standalone DVR
Video Channels
8
Image Resolution
1920x1080
Package Content
DVR, external power adapter, mounting kit, mouse, 4 security stickers
Network cable - RJ-45 - RJ-45 - 1 pcs. , HDMI cable - 1 pcs.
Country Kits
United Kingdom
Security DVR
Networked
Smartphone support
Hard Drive
Quantity Installed
1
2 TB
Serial ATA
Supported Max Total Capacity
4 TB
Video Input Ports
BNC x 8
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 1
Audio Output Ports
RCA x 1
Camera Control Interface (PTZ)
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2
21.5 cm
21.5 cm
4.5 cm
