- A cutting edge & easy to use surveillance system with 1080p high definition video to see & protect your premises
- Set & forget by recording from 4 channels for 160 days+ onto a 1TB hard drive
- Just add up to 4 compatible cameras for complete 4 channel monitoring
- Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
- View live or playback video in high definition on your HDTV, LCD screen or monitor via HDMI connection or VGA port
- Surveillance in the palm of your hand with live viewing on Smartphone & tablets including iPhones, iPads & Android devices using the free SwannView Link app
- Cut the cost of crime & know what’s happening with this HD security system to suit front & back doorways, yards, homes, offices, small businesses & retail stores
- Swann DVR4-44550 - standalone DVR - 4 channels
- Standalone DVR - 4 channels - networked
- Compression Format
- H.264
- TV System
- NTSC/PAL
- Image Resolution
- 1920x1080
- Hard Drive
- 1 x 1 TB
- Hard Drive(s) Supported
- Total capacity: 3 TB
- 21.5 cm x 24 cm x 4.5 cm
- Country Kits
- United Kingdom
- Standalone DVR
- Video Channels
- 4
- Audio Channels
- 4
- TV System
- NTSC/PAL
- Image Resolution
- 1920x1080
- H.264
- Package Content
- DVR, external power adapter, mounting kit, mouse
- Cables Included
- Network cable - RJ-45 - RJ-45 - 1 pcs. , HDMI cable - 1 pcs.
- Country Kits
- United Kingdom
Security DVR
- Record Events
- Motion detection, scheduled, manual
- Networked
- Smartphone support, 'Peer to Peer' technology
Hard Drive
- Quantity Installed
- 1
- Capacity
- 1 TB
- Interface
- Serial ATA
- Supported Max Total Capacity
- 3 TB
- DDNS Support
- Network Interfaces
- Ethernet 10Base-T/100Base-TX
- Video Input Ports
- BNC x 4
- Video Output Ports
- HDMI x 1, VGA x 1
- Audio Input Ports
- RCA x 1
- Audio Output Ports
- RCA x 1
- Network Port
- 10/100Base-T
- Other Ports
- USB 2.0 x 2
- 21.5 cm
- 24 cm
- 4.5 cm
