Product
Swann Communications 16 Channel DVR 1080p
Quicklinx: CMVFWS00 Mfr#: SWDVR-16455H-UK
  • A cutting edge & easy to use surveillance system with 1080p high definition video to see & protect your premises
  • Set & forget by recording from 16 channels for 80 days+ onto a massive 2TB hard drive
  • Just add up to 16 compatible Swann PRO-H855, H856 or T850 series cameras for full 16 channel monitoring
  • Save time & have peace of mind by easily locating incident video, then transfer to external storage via USB or network
  • View live or playback video in high definition on your HDTV, LCD screen or monitor via HDMI connection or VGA port
  • Surveillance in the palm of your hand with live viewing on Smartphone & tablets including iPhones, iPads & Android devices using the free SwannView Link app
  • Cut the cost of crime & know what’s happening with this expandable HD security system to suit homes, offices, small businesses & retail stores
Swann DVR16-4550 - standalone DVR - 16 channels
Standalone DVR - 16 channels - networked
Image Resolution
1920x1080
Hard Drive
1 x 2 TB
28.5 cm x 23 cm x 5 cm
Country Kits
United Kingdom
Standalone DVR
Video Channels
16
Image Resolution
1920x1080
Package Content
DVR, external power adapter, mouse
Network cable - RJ-45 - RJ-45 - 1 pcs. , HDMI cable - 1 pcs.
Country Kits
United Kingdom
Security DVR
Networked
Hard Drive
Quantity Installed
1
2 TB
Serial ATA
Network Interfaces
Ethernet 10Base-T/100Base-TX
Video Input Ports
BNC x 16
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 1
Audio Output Ports
RCA x 1
Network Port
10/100Base-TX
Other Ports
USB 2.0 x 2
28.5 cm
23 cm
5 cm
