Stone Computers NT310 Core i3-4100 4GB 320GB Windows 8.1 Professional 64 Bit
Quicklinx: B7ZTWS00 Mfr#: 621892
  • Core i3
  • Windows 8.1 Pro 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Introducing the NT310-H - the newest addition to the Stone family and 25% thinner than the NT309.
Boasting the latest 4th Gen Intel® Core™ processor, our brand new NT310-H offers a host of features including the latest Intel® HD Graphics 4000, TPM as standard and additional security features in a slimmer chassis.
Subject to rigorous heat and stress tests, the NT310-H has been designed to withstand the trials and tribulations of daily use - from students daily removal from a laptop trolley to full mobile working solutions out in the field with larger public sector organisations. Customisation options need only be limited to your imagination and you can be certain of a high performing and cost effective solution to match any requirements.
Operating System Windows 8.1 Professional 64 Bit Digital Key
Processor Intel Core i3-4100m 2.50GHz
Main Chipset Intel® HM86 Express Chipset
System Memory 4GB 1600MHz DDR3 Non-ECC CL11 SODIMM
Memory Slot 2 x Slot SODIMM
Display LCD 15.6" HD (1366x768) Slim 16:9 LED Display (Non-Gloss)
Graphics Processor Intel® HD4000
Graphics Memory Intel® Dynamic Video Memory Technology up to 1.7GB
Hard Drive 320GB 2.5 SATA 2 Internal 5400RPM HDD
Optical DVDRW or Blanking Plate
Communication
Wired LAN (RJ45) 10/100/1000
Wireless LAN Intel® 2230 802.11 B,G,N or Intel® 6235 802.11 A,B,G,N WWAN Optional HSDPA Module
Bluetooth™ Bluetooth™ 4.0 + EDR
Multimedia
Sound HD (High Definition) Audio
Speakers 2 Watts Stereo Speakers (1 W x 2)
Integrated Camera 2MP Webcam
Others
I/O Ports - HDMI , VGA, Headphone-out, Mic-In, Internal Mic, 2 x USB 3.0, 2x USB 2.0, 9-in-1 Card Reader, RJ45 and DC-In
Security - BIOS Boot Up
Password / HDD Password / Kenssington lock
AC Adaptor - 65W AC 100-240V,50-60Hz, DC Output 19V 3.42A
Battery - 6 Cell Smart Lithium-Ion Battery Pack- 62WH
Dimensions (W x D x H) - 374 (W) x252 (D) x25.4(H)mm
Weight - 2.2kg
Warranty 5 Yr NBD OSW
  • High performance with style
    Boasting the 4th Gen Intel Core processor, the NT310-H offers a host of features including the Intel HD Graphics 4000, TPM as standard and additional security features in an ultrabook style chassis. Customization options need only be limited to your imagination and you can be certain of a high performing and cost effective solution to match any requirements.
  • Tough
    Subject to rigorous heat and stress tests, the NT310-H has been designed to withstand the trials and tribulations of public sector use - from students daily removal from a laptop trolley to full mobile working solutions out in the field with larger public sector organizations.
Stone NT310-H - 15.6" - Intel Core i3 - 4100M - 4 GB RAM - 320 GB HDD
Notebook
Operating System
Win 8.1 Pro 64-bit
Intel Core i3 (4th Gen) - 4100M / 2.5 GHz / 3 MB Cache
4 GB DDR3L
Storage
320 GB HDD / 5400 rpm
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4600
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
6-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip
37.4 cm x 25.2 cm x 2.54 cm
2.2 kg
Limited warranty - 5 years - on-site , Limited warranty - battery - 3 years , Limited warranty - power adapter - 3 years
Notebook
Operating System
Processor / Chipset
CPU
Intel Core i3 (4th Gen) 4100M / 2.5 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Chipset
Mobile Intel HM86
RAM
4 GB
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Audio & Video
Graphics Processor
Max Allocated RAM Size
1.7 GB
Camera
Resolution
2 Megapixel
Sound
Stereo speakers, microphone
High Definition Audio
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Intel Centrino Wireless-N 2230
Network Interface
Gigabit Ethernet
6-cell Lithium Ion
62 Wh
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
Headphone output , 2 x USB 2.0 , VGA , HDMI , Microphone input , 3 x USB 3.0 , LAN
Memory Card Reader
9 in 1
Security
Power adapter
2.2 kg
