STM Dux Plus Duo (iPad 7th Gen) EDU Black
Quicklinx: G020WS00 Mfr#: STM-222-237JU-01
£17.82 ex VAT
£21.38 inc VAT
Tested to exceed U.S. Mil-Spec drop tests, Dux Plus Duo withstands the rigors of the classroom, work, and everyday use. Designed with educators' and IT professionals' input, the case features a magnetic closure, a transparent back for asset tagging or user customization, and integrated storage that can accommodate either the Apple Pencil or Logitech Crayon.
  • A case all your own
    Completely transparent materials used for the back panel allow you to customize your device with personal images, scan a tagging barcode, or simply let the beauty of your device shine through. But there's one more thing: this stylish case still provides the maximum level of protection for your digital gear.
  • Instant on/off cover
    Chances are, you probably feel like you're charging and recharging your digital devices more often than you'd like. This smart case helps you maximize the time between juicing up. The instant on/off cover wakes up your tablet when it's open and puts it to sleep when it's closed. It's a real (battery) lifesaver.
STM dux Plus Duo - flip cover for tablet
Flip cover for tablet
Pricing Type
Academic
25.5 cm x 19.41 cm x 1.7 cm
339 g
Material
Polycarbonate, thermoplastic polyurethane (TPU)
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
25.5 cm
19.41 cm
1.7 cm
339 g
Pricing Type
Academic
Rugged
Material
Carrying Case
Protective cover
Recommended Use
For tablet
Protection
Drop-proof
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Additional Compartments
Apple Pencil
Cover Features
Stand function
Max Height of Shock Resistance
1.22 m
Brand: STM
