SteelSeries World of Warcraft MMO Gaming Mouse Legendary Edition - Wired - USB
Quicklinx: 7SVDWS00 Mfr#: 62050
LEGENDARY AWAITS
DO YOU HAVE WHAT IT TAKES TO BE LEGENDARY?
SteelSeries brings World of Warcraft players a finely crafted weapon of precision with the SteelSeries World of Warcraft MMO Gaming Mouse: Legendary Edition. Arm yourself with a versatile tool on your journey through Azeroth battling old foes and discovering new adventures. Be bold. Be Legendary.
WELCOME ADVENTURERS
Built for players of all types - be they casual fan or dedicated raider, rookie or guild leader - the Legendary Edition mouse is designed to enhance your game play. Sophisticated software functionality lets you easily customize the mouse to suit your individual play style
THE FIT
For a game that has become a lifestyle for many, the tools that are used to explore and dominate must be perfectly sized for comfort - especially for long sessions of dungeon crawling or raiding.
LUCKY NUMBER 11
Sleeker in size but just as powerful, the Legendary Edition is the little brother to its predecessor the World of Warcraft®: Cataclysm™ MMO Gaming Mouse. Tested by World of Warcraft® gamers and co-designed with Blizzard Entertainment®, the new Legendary Edition has 11 programmable buttons, ergonomically positioned for comfortable gameplay
CONFIGURE YOUR SETTINGS IN THE GAME
Plug in your mouse. Start your game. Configure all of your mouse settings from illumination to macros to button assignments directly from the World of Warcraft® interface.
DRAG & DROP POWER
The intuitive drag & drop interface of the SteelSeries software empowers users to:
- Program all 11 buttons with more than 130 preset game commands
- Create custom macros and/or use the in-game macro scripting language
Optical sensor
Frames Per Second: 3600
Inches Per Second: 130
Counts Per Inch: 3200
Acceleration: 30 G
Lift Distance: 2mm
ILLUMINATION AND PULSE
For a game that's filled with choices and personalization, it's obvious that the same should be true with how your tools play, look and feel. The World of Warcraft MMO Gaming Mouse: Legendary Edition offers more than 16.8 million color options and 4 levels of pulsation including Low, Medium, High and Off. So there's sure to be a combination to suit every mood and occasion.
BEHIND THE DESIGN
Inspired by the legendary sword Thunderfury, the mouse features an impressive lightening bolt design evoking the power of the Blessed Blade of the Windseeker. The sword is the final reward at the end of a long and difficult journey - and an incredible boon for the dedicated souls who dare to take on the challenge.
  • Built for players of all types
  • Fit for games
  • Programmable buttons
    Sleek in size but just as powerful, the Legendary Edition has 11 programmable buttons, ergonomically positioned for comfortable game play.
  • Configure your settings in the game
    Plug in your mouse. Start your game. Configure all of your mouse settings from illumination to macros to button assignments directly from the World of Warcraft interface.
  • Illumination and pulse
    For a game that's filled with choices and personalization, it's obvious that the same should be true with how your tools play, look and feel. The World of Warcraft MMO Gaming Mouse: Legendary Edition offers 4 levels of pulsation including Low, Medium, High and Off. So there's sure to be a combination to suit every mood and occasion.
SteelSeries World of Warcraft - [Legendary] Edition - mouse - USB
Mouse
Wired - USB
8.1 cm x 11.5 cm x 4 cm
115 g
Movement Detection Technology
Optical
Buttons Qty
11
Movement Resolution
3200 cpi
Performance
30 G maximum acceleration, 130 inches per second, 3600 fps
Illumination
Apple MacOS X, Microsoft Windows 2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
Mouse
8.1 cm
11.5 cm
4 cm
115 g
Input Device
Wired
USB
Optical
Buttons Qty
11
Movement Resolution
3200 cpi
Performance
Illumination
1 x USB - 4 pin USB Type A
