SteelSeries Shift World of Warcraft® Cataclysm Limited Edition - Gaming Keyboard - USB
Quicklinx: 7TNMWS00 Mfr#: 64341
The SteelSeries Shift World of Warcraft: Cataclysm Edition Bundle presents gamers with predefined game mods and an intuitive layout of the most common commands, actions and emotes. The keyset helps groups run more smoothly through its ability to mark targets for added group and raid functionality. The SteelSeries Shift keyset provides functionality that reflects changes that have come over the game since the last expansion. Its labeled and color coded keys, together with the World of Warcraft: Cataclysm artwork and functionality, will immerse players into the world of Azeroth and help to accelerate game mastery.
The SteelSeries Shift World of Warcraft: Cataclysm Edition Bundle provides gamers with predefined game mods and an intuitive layout of the most common commands and actions for specific game genres and titles. With the functionality to customize every key on the keyset, on-the-fly macro recording, and the anti-ghosting of up to 7 simultaneous keystrokes, the SteelSeries Shift World of Warcraft: Cataclysm Edition Bundle is designed to help in the mastery of any game.
  • Master the game
    It features labeled keys and one-touch macros grouped intuitively for quick access.
  • Ergonomics
    It features ergonomic design with 3 leg levels and non-slip base.
  • Anti-ghosting
    Anti-ghosting capability allows for 7 simultaneous keystrokes.
  • Full featured
    It's equipped with two USB 2.0 ports as well as a standard keyset for everyday use.
  • Media keys
    Shift also offers easy access to media controls, making it a convenient companion even when you are not destroying your friends and foes.
  • Audio and USB hubs
    The Shift base was also designed to make it easy to plug in your peripherals.
SteelSeries Shift Cataclysm - keyboard
Keyboard
USB
Wired
Hot Keys Qty
8
Hot Keys Function
Multimedia, programmable, macros buttons, macro record button
Detachable wrist rest, tilt legs, interchangeable keysets, gold-plated connector, commands labelled keys
49 cm x 19 cm x 4 cm
Keyboard
USB
Input Device
Hot Keys Qty
8
Hot Keys Function
Region
United Kingdom
Anti-ghosting
49 cm
19 cm
4 cm
Extra keyset
1 x USB cable
C-Tick, BSMI, GS, FCC, RoHS, KCC, WEEE
Apple MacOS X, Microsoft Windows Vista / XP / 7
