SteelSeries Sensei Wireless Laser Gaming Mouse
Quicklinx: B241WS00 Mfr#: 62250
SteelSeries Sensei Wireless Laser Mouse
The Sensei Wireless is SteelSeries' innovative ambidextrous premium laser mouse designed for the gamer who values lag-free trusted Sensei performance and outstanding beauty. Delivering freedom from wires, unparalleled performance, maximum customization and a stand-out-from-the-crowd look, this mouse proves that sometimes beauty is more than skin deep.
Enhanced Sensei Performance
Sensei Wireless uses the latest in wireless technology to deliver exactly the same performance of our wired Sensei tournament-grade mouse. We equipped the mouse with the highest polling rate on the market (1000 Hz), delivering a 1ms response time that eliminates wireless lag. We use a high-speed, proprietary 2.4 GHz wireless solution that is optimized for extremely high data throughput and allows for incredibly low latency. Additionally the Pixart ADNS 9800 laser sensor allows you to ramp up the CPI to 8200.
Aesthetics
Winning may be everything, but why not do it in style? Sensei Wireless was refined from the ground up to make it a stunning addition to your gaming setup. Ergonomics, metal and illumination blend together in a mouse that looks as sharp as it performs.
Endless Worry-Free Play
Sensei Wireless erases all the preconceived notions that wireless mice have faced over the years. Performance, battery life, charging. . . solved. We took out the hassle of wireless mice so you can spend more time gaming.
Battery Life
Out of the box Sensei Wireless features 16 hours of life with its rechargeable battery so you don't run out of juice during those marathon sessions. And if you find yourself running low, just switch to wired mode and play on while the mouse charges.
Illuminated Base
The included base station's illumination keeps you aware of the mouse's charge status. This makes it easy to monitor when the battery gets low and removes the guesswork over just how much battery you have left. You can customize the illumination to give it your own look, move the battery charge status to the mouse if you like.
Battery Save Mode
If 16 hours in balanced mode isn't enough when it comes to battery life we added a battery save mode that can be turned on within SteelSeries Engine 3. This pushes the limits to deliver up to 20 hours of uninterrupted wireless play.
Superior Gaming Performance * Cutting edge laser sensor - superior performance * Max. configurable* battery life~ 20 hrs continuous play * Exact features - Aim, Accel, Lift, Snapping* * Configurable - frame rate to 12,000 FPS, CPI to 8,200 * 1ms customizable* response time - no lag Optimal Ergonomic Design * 1ms Response rate - lag free performance * Seamlessly switch between wireless and wired * SteelSeries switches >30 million clicks lifecycle * 8 programmable buttons (incl. CPI) * Multi-color battery and RF link indicator * Cloud based profiles Bold Look * Illuminated aluminum charging base * Aluminum accent w/ rubberized soft touch * 16.8 million color illumination on base and mouse * Illumination color, intensity and pulsation effects.
Package contents
  • Mouse
  • Base Station
  • USB Cable
  • SteelSeries Sticker
  • Documentation
  • Double sensitivity
    A powerful 32-bit ARM processor allows Sensei to reach up to 11,400 DCPI.
  • Illuminate
    Light up your wheel, CPI indicator or SteelSeries logo. Or turn it all off.
SteelSeries Sensei - mouse - USB, 2.4 GHz
Mouse
Wireless, wired - USB, 2.4 GHz
6.9 cm x 12.9 cm x 4.1 cm
120 g
Movement Detection Technology
Laser
Buttons Qty
8
Movement Resolution
8200 cpi
Performance
30 G maximum acceleration, 1 ms response time, 1000 reports per second, 150 inches per second, realtime sensitivity switching 50 - 8200 cpi
Programmable buttons, illuminated scrolling wheel, switchable resolution, soft rubber grip, multicolour LEDs, braided cable, recharging, 4-zone illumination, Pixart ADNS 9800 laser sensor
Apple MacOS X, Microsoft Windows
Mouse
6.9 cm
12.9 cm
4.1 cm
120 g
Input Device
Wireless, wired
USB, 2.4 GHz
Laser
Buttons Qty
8
Movement Resolution
8200 cpi
Performance
1 x USB - 4 pin USB Type A
Illuminated aluminum charging base station
Plug and Play
