SteelSeries Sensei Pro Gaming Laser Mouse- 8 button(s) - wired - USB
Quicklinx: 7SVGWS00 Mfr#: 62150
Bow to the master
A powerful 32 bit ARM processor allows Sensei to reach up to 11,400 DCPI. The most customizable mouse in the world. Whatever you want, however you want it. Light up your wheel, CPI indicator or SteelSeries logo. Or turn it all off. Get your own lift distance regardless of surface. Always. You have the authority now. Via the built-in menu, you can customize on the go - at the touch of your scroll wheel.
MEET THE SENSEI
Since the release of our first mouse, we have been using Japanese-inspiration in our naming of them. Our mice are built for performance and tournament-style play; Ikari means anger, Xai means talent, and the list of product names goes on. The Sensei is our version of the grand-master in our Do Jo. It is the teacher. The one everyone bows to, the one who knows tricks and secret moves that everyone wants to learn - but so very few can ever hope to master. It's a fitting name. Master your game. Meet the Sensei.
WINNING, IT'S THE WAY OF THE SENSEI
The name fits because everything we ever learned about mice, everything we ever researched, everything we ever discovered, everything that makes a mouse great, is exactly what we built the SteelSeries Sensei around. The DNA of Sensei is programmed to win. It is one of those rare hardware products forged by love and science, trial and error, passion from professional gamers and a desire to push the envelope. SteelSeries Sensei was born for tournament victory; it was built to help you win.
SIZE AND WEIGHT
-Weight: 102 grams (0.22 lbs)
-Height: 38,7 mm (1.5 in)
-Width: 68,3 mm (2.7 in)
-Length: 125,5 mm (4.9 in)
DOUBLE YOUR SPEED
SteelSeries Sensei can be fast, like really light-speed fast, if you need that kind of speed. Because we use a 32 bit ARM processor in the mouse, we can double (x2) your mouse sensitivity.
Our default CPI range: 1 to 5,700 CPI.
Our Double CPI range: 5701 to 11,400 CPI.
This feature is particularly useful for people using multiple monitor and similar environments.
BEST-IN-CLASS TECHNOLOGY
Featuring a state of the art laser sensor that offers a consistent and reliable performance, the SteelSeries Sensei boasts 10.8 megapixel HD image correlation at up to 12,000 frames per second and the ability to handle tracking movements of up to 150 inches per second.
ADVANCED MACROS
Thanks to the support of the SteelSeries Engine software, you can record even extremely long and advanced macros to the Sensei. The macros can be layered and can include keystrokes and precise timing. How you will decide to use this advanced feature is up to you (choose your configurations wisely and adhere to any rules that you may need to abide by during gameplay); we are only presenting you with the capabilities for endless possibilities.
32 BIT ARM PROCESSOR
The processor in SteelSeries Sensei is a 32 bit ARM processor and it is as fast as the original Pentium 75 MHz processor released by Intel in 1994. That is fast, incredibly fast. This reference may sound like overkill, but it's this type of power that allows us to do sophisticated calculations directly on the mouse - without the need for software drivers and without having to rely on the user's computer.
Our industry leading ExactTech settings, like ExactSens, ExactRate, ExactAim and more, are calculated directly on the mouse providing the user with a mouse movement that is completely free of any interpolation or extrapolation, without any delay, filtering and without using up memory or resources on the user's computer.
DEVELOPED WITH THE BEST
We are proud to be associated with some of the best players in the world of eSports. We maintain strong relationships and have continuous dialogue with teams like SK Gaming, Fnatic, Evil Geniuses, Natus Vincere and others who help in the development and improvement of our products.
To ensure maximum performance in all gaming scenarios we enlisted help from world-class StarCraft® II, Counter-Strike, DotA, League of Legends, Heroes of Newerth, WarCraft® III and Doom players. Click on the picture below for a list of the players who helped us with testing and refinement of the Sensei. We owe them a lot of thanks, so if you like the Sensei these are the players that helped make this mouse what it is.
LIGHT `EM UP
3 different zones on the Sensei (the wheel, the CPI indicator and the back) can be programmed individually - in 16.8 million different colors. It's another way for you to personalize your mouse. It also brings a very real benefit to users who utilize multiple profiles: by giving them different colors, you can quickly switch between profiles and also ways know which profile is active. For those of you who don't like glowing shiny stuff on your desktop, you can completely switch off all illumination.
  • Double sensitivity
    A powerful 32-bit ARM processor allows Sensei to reach up to 11,400 DCPI.
  • Illuminate
SteelSeries Sensei - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
6.83 cm x 12.55 cm
102 g
Movement Detection Technology
Laser
Buttons Qty
8
Movement Resolution
5700 cpi
Performance
150 inches per second, 1 ms response time
30-million clicks, scrolling wheel, non-slip coating, adjustable lift distance, illuminated scrolling wheel, on-the-fly CPI switching, RGB 16.8 millions multi-colour illumination, programmable buttons
Cable Length
2 m
1 x USB cable - integrated
Apple MacOS X, Microsoft Windows 2000/XP/Vista/7
Mouse
Orientation
6.83 cm
12.55 cm
102 g
Input Device
Wired
USB
Laser
Buttons Qty
8
Movement Resolution
5700 cpi
Performance
Cable Length
2 m
1 x USB - 4 pin USB Type A
Plug and Play
Software Included
SteelSeries Engine 3
