SteelSeries Apex (RAW) Gaming Keyboard
Quicklinx: 8YFLWS00 Mfr#: 64123
Press Any Key to Win
Introducing the SteelSeries Apex [RAW], a gaming keyboard designed to enable users to react quickly, move effortlessly, and customize its performance for every game. Effortlessly navigate your way around the keyboard with raised macro keys, and a unique W-key with tactile bumps for improved WASD speed, along with the visual support of bright white illumination.
Superior Design
Apex [RAW] is made up of sleek lines and low-profile keys that bring together beautiful form and optimized function.
Faster Return to WASD
Small bumps on the W-key provides a faster return to WASD. When you quickly have to type a message or execute a command, we want to make sure that you find your way back to WASD as quickly as possible without having to look.
Raised Macro Keys
The macro keys above the F-keys feature a raised design that allow you to locate them without looking and execute devastatingly fast key combinations. Simply swipe your finger down from the macro key onto the F-key for quick key combinations.
34 More Ways to Win
The Apex [RAW] features 17 independent macros keys that are each capable of up to 2 layers. This equates to 34 potential macros.
Layer Select Buttons
Switch between macro layers quickly and easily thanks to 2 quick-access keys on the upper left corner that allow you to select your desired macro layer.
Light `em up
Find your way in the dark and locate your macros with brilliant white illumination featuring 8 levels of intensity.
Disable Windows Key
Simply hold down the SteelSeries key and tap the Windows key to disable it. This simple key combination will disable and enable the windows key without the need for software or complicated menus.
The SteelSeries Key
The special SteelSeries key on the right hand side of the key lard allows you to access special functions like disabling the Windows key.
With the Apex, we left the windows key on the left side of the keyboard for commands and shortcuts that are frequently used when not gaming.
EXTRA ARROWS
We added two arrow keys for a bit of extra directional convenience.
SUPERIOR ANTI-GHOSTING
The SteelSeries Apex and Apex [RAW] gaming keyboards support anti-ghosting for 20 keys located in the most-used gaming areas on the keyboard. Out of these 20 capable keys, users can press up to 6 of them simultaneously, allowing those key presses to register and without locking the keyboard.
PLUG, PLAY, WIN
There's no need to install software of any kind in order to use the Apex [RAW]. Without software many features will work including disabling of the windows key and more. However, for the full experience and for the gamers who want really advanced customization options, the Apex [RAW] is supported by SteelSeries Engine technology.
Swappable Feet
Swappable rubber feet allow you to find the most comfortable gaming angle for those long gaming sessions.
  • Low-profile keys
    Introducing the SteelSeries Apex, a gaming keyboard designed with low-profile, fast-action keys which allow owners to react quickly, move strategically and gain the competitive edge.
  • Stylish and intuitive design
    The combination of 16.8 million color illumination, low-profile keys and sleek lines come together giving Apex beautiful form and optimized function.
  • Under the hood
    SteelSeries Engine has you covered when it comes to customizing lighting, macros, and even more Apex options. Or you can plug Apex in and get right to the gaming.
  • Superior anti-ghosting
    The SteelSeries Apex gaming keyboard supports anti-ghosting for 20 keys located in the most-used gaming areas on the keyboard. Out of these 20 capable keys, 6 can be used simultaneously, allowing those key presses to register and without locking the keyboard. These keys are: 1, 2, 3, 4, 5, Q, W, E, R, A, S, D, F, L-Ctrl, L-Shift, Space, and the four arrow keys.
  • Macros galore
    The Apex gives you 88 more ways to win. 22 independent macro keys are each capable of up to 4 layers (via layer select keys), for a total of 88 potential macros. Of course, much of the keyboard is also programmable making for an enormous total of 504 programmable keys. And to top it off the macro keys above the F-keys are raised up for easy access and combinations.
  • Fast return to WASD
    Small bumps on the W-key provide a faster return to WASD. When you quickly have to type a message or execute a command, SteelSeries wants to make sure that you find your way back to WASD as quickly as possible without having to look.
  • Extra keys
    SteelSeries wanted to give you even more control with Apex so was added an array of other keys. Independent media and volume keys provide instant access to media control and more. Two more arrow keys give extra directional convenience. The SteelSeries key allows you to access special functions like disabling the Windows key.
  • Activezone lighting
    The Apex features 5 independent color zones that are each capable of 16.8 million colors. These can be customized to create a unique color scheme for each of your macro layers. This allows you to quickly determine which macro layer is enabled and helps finding groups of your macros according to their color. Imagine a yellow theme for harvest macros, blue theme for defend macros, red for attack macros and more. The possibilities are limitless.
  • Swappable feet
    Swappable rubber feet allow you to find the most comfortable gaming angle for those long gaming sessions. You can raise or lower Apex depending on which feet you decide to game with.
  • Integrated USB hub
    An integrated USB hub adds to two USB ports to your setup giving you quick access to storage right on your Apex keyboard.
  • SteelSeries Engine
    If you want the full Apex experience then SteelSeries Engine is the way to go. Download the software suite for complete control over your keyboard. The options include control over your lighting intensity levels, unlimited macro creation, an unlimited number of profiles, and complete button remapping.
  • Plug and Play
    There's no need to install software of any kind in order to use the Apex. Without the software many features will still work including disabling of the windows key and more.
SteelSeries Apex Gaming [RAW] - keyboard - UK - glossy, textured
Keyboard
Backlit
White
USB
Wired
Localization and Layout
Hot Keys Qty
17
Hot Keys Function
Multimedia, programmable, macros buttons
Tactile bumps, low profile keys, 2 stage tilt angle stand, extra arrows, 8 levels of illumination intensity, 2 macro layers, swappable feet
Glossy, textured
Keyboard
Backlit
White
USB
Input Device
Hot Keys Qty
17
Hot Keys Function
Keyboard Technology
Rubber dome
Anti-ghosting
Glossy, textured
1 x USB cable
Plug and Play
Included Software
SteelSeries Engine
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
