SteelSeries 3H is a compact lightweight headset, specially designed for gamers who frequently visit LAN-events and other gaming events. SteelSeries 3H can be collapsed for easy and safe transportation and features a pull-out microphone system. A volume regulator on the cord enables you to quickly adjust the sound in the headset and mute the microphone.
Retractable Microphone
The retractable microphone in the left earcup makes this headset perfect for gaming without having the microphone being an annoying device hanging out all the time.
Easy to Transport
SteelSeries 3H VR collapses at the top of each earcup, making it an easy to store for travel. Bring your headset to a LAN tournament or friends house without having to worry it'll break along the way.
Easy Access Volume Control
SteelSeries 3H VR features an integrated volume controller, which enables you to adjust the sound in the headset and mute the microphone on-the-fly.
Passive Noise Reduction
The 3H VR features leather earcups with a noise reducing foam, which helps to muffle the outside world and allow you to focus on the important audio and voice communication happening inside your game.
AND THE NUMBERS
Headphones:
Freq. response: 10 - 27.000 Hz
Impedance: 50 Ohm
SPL@1kHz, 1Vrms: 102 dB
Cable: 2 m / 6,6 ft.
Microphone:
Freq. response: 50 - 18.000 Hz
Pick-up pattern: Non-directional
Sensitivity: -40 dB
Impedance: 2,2K Ohm
