StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe
Quicklinx: FLYJWS00 Mfr#: PEX8M2E2
Type: Interface adapter
HD Size: M.2
Power Supply: [N/A]
10 In Stock
£129.01 ex VAT
£154.81 inc VAT
Upgrade your system speed and performance with this Dual M.2 PCIe SSD Adapter. It lets you add two high performance, enterprise-class PCIe 3.0 M.2 SSDs (NVMe and AHCI) into the PCIe 8-lane or larger slot of your desktop workstation or server.
The expansion card lets you take full advantage of the fast performance and compact size of PCIe M.2 internal solid-state drives. With the M.2 PCIe based drives in place, the adapter increases your storage capacity and gives your computer a significant speed boost, enhancing data transfer rates.
The dual M.2 to PCIe expansion card employs a high-speed ASM2824 switch, allowing you to access two drives at the same time. Since the adapter card does not rely on PCIe bifurcation, it can easily be integrated into all systems, new and legacy.
The M.2 PCI express adapter also gives you the flexibility to access your M.2 PCIe SSDs individually. Or, you can utilize software RAID to build a RAID array to add redundancy or enhance system performance.
The adapter? connects directly to your computer motherboard to support two PCIe M.2 SSDs through a x8 PCIe expansion slot. The adapter is compatible with PCIe 3.0 motherboards and is backward compatible with PCIe 2.0 and PCIe 1.0.
The PCIe M.2 NGFF (M Key) adapter supports PCIe 3.0 NVMe and PCIe-AHCI M.2 SSDs including 2242, 2260, and 2280 drives, supporting the most common drive sizes: 42, 60, and 80 mm lengths.
The expansion card comes with a full-profile bracket pre-installed, and includes a half-height / low-profile bracket, for installation in small form-factor computers.
Vented brackets on the PCIe M.2 NGFF SSD adapter card increases air flow to assist in heat dissipation.
  • Versatile storage expansion
    This adapter supports M.2 NGFF solid-state drives in various sizes, allowing for flexible storage configurations to meet different needs.
  • Effective heat management
    Designed with ventilation holes, this adapter promotes airflow, helping to maintain operating temperatures for reliable performance.
  • Robust compliance standards
    The product meets several compliance standards including FCC, RoHS, WEEE, and RCM, ensuring safety and environmental responsibility.
  • Long lifespan
    With an MTBF of 3,336,103 hours, this adapter is built for durability, providing long-term reliability for your storage needs.
StarTech.com Dual M.2 PCIe SSD Adapter Card, x8 / x16 Dual NVMe or AHCI M.2 SSD to PCI Express 3.0, M.2 NGFF PCIe (M-Key) Compatible, Vented, Supports 2242, 2260, 2280, JBOD, Mac & PC - Full/Low-Profile Brackets (PEX8M2E2) - interface adapter - M.2 Card - PCIe 3.0 x8 - TAA Compliant
Interface adapter - plug-in card - low profile
Bus Type
PCIe 3.0 x8
Red
Supported Form Factor
Expansion Slot to M.2
Expansion Bays
2 x internal - M.2 NGFF 2242/2260/2280
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Supported Devices
Solid state drive
Max Storage Devices Qty
2
TAA Compliant
2.2 cm x 17.4 cm x 12.2 cm
88 g
M.2
Host Bus
PCIe 3.0 x8
Red
Storage Controller
M.2 Card
Supported Devices
Solid state drive
2
ASMedia ASM2824
Bays
2 x - 2 pin IDC
Low-profile bracket, full-height bracket, half-height bracket
Supports AHCI mode, ventilation holes
MTBF
3336103 hours
FCC, RoHS, WEEE, RCM
Environmental Standards
TAA Compliant
2.2 cm
17.4 cm
12.2 cm
88 g
Shipping Width
21.5 cm
Shipping Depth
15.5 cm
Shipping Height
4.5 cm
Shipping Weight
195 g
5 °C
70 °C
15 - 90%
FLYJ StarTech.com M.2 NVMe PCIe SSD Enclosure - IP67 water/dust resistance In Stock £63.05
HD Size: M.2
Power Supply: [N/A]
