StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90’
Quicklinx: FBZ4WS00 Mfr#: PRESREMOTEG
31 in stock
£35.84 ex VAT
£43.00 inc VAT
This wireless presentation remote lets you engage your audience, draw their attention and control your presentation. It's ideal for presenting in large lecture halls, or conference centers.
With a built-in green laser pointer, the presentation remote lets you guide your audience's attention to critical information in your content. It's perfect for PowerPoint presentations, websites or any other documents you want to share.
The green laser works on surfaces where red lasers won't display. It appears nicely on bright projector or LCD/LED HD screens.
The presentation clicker features a wireless range of 90 ft. (27 m). It gives you control of what's on the screen throughout the room, and the freedom to move around and present as if you were at your computer.
You can: Navigate through your slides; Black out the screen to focus your audience's attention solely on you or something else in the room; Control the volume of a video.
The remote features a sleek, ergonomic design and includes the required batteries along with a protective carrying case, for total portability. You can store the wireless receiver inside the presentation remote when you're not using it and the remote will automatically power off.
The USB receiver works with virtually any Mac or Windows computer. Simply plug the receiver into your laptop and you're ready to present.
StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90' presentation remote control - black
Presentation remote control
Enclosure Colour
3.1 cm x 13.4 cm x 2.5 cm
120 g
Radio
Supported Devices
Projector, LCD display
Wireless Technology
2.4 GHz
Max Operating Distance
27 m
2 AAA type
3.1 cm
13.4 cm
2.5 cm
120 g
Enclosure Colour
Radio
Wireless Technology
2.4 GHz
Supported Devices
27 m
Built-in laser pointer, LED indicator
Carrying case, 2 AAA batteries, USB wireless receiver
FCC, RoHS, Laser Class 2
Shipping Width
9.6 cm
Shipping Depth
19 cm
Shipping Height
4.5 mm
5 °C
45 °C
30 - 80%
2 AAA type
FBZ4 StarTech.com Wireless Presentation Remote In Stock £25.59
FBZ4 StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90’ In Stock £35.84
Price Range Ex VAT: 0 - 50
