This presentation remote control helps you deliver seamless presentations by combining intuitive navigation and a laser pointer in a single compact unit.
Being confined to your computer isn't the most effective way to deliver a presentation, especially when you're trying to engage your audience.
With a wireless range of 90 ft. (27 m), this presentation clicker puts you in control of what's on your screen, giving you the freedom to move around the room while controlling your presentation as if you were at your computer. This is ideal for presenting in large lecture halls or conference centers.
With a built-in laser pointer, the presentation remote lets you guide your audience's attention to critical information in your content. It's perfect for PowerPoint presentations, websites or any other documents you want to share with your audience.
The remote control features a sleek, ergonomic design and includes the required batteries along with a protective carrying case, for total portability. You can store the wireless receiver inside the presentation remote when you're not using it. The USB receiver is supported by generic HID drivers ensuring it will work with virtually any Mac or Windows computer.
- StarTech.com Wireless Presentation Remote with Red Laser Pointer - 90 ft. - PowerPoint Presentation Clicker for Mac & Windows (PRESREMOTE) presentation remote control
- Presentation remote control
- 3.1 cm x 13.4 cm x 6.6 cm
- 120 g
- Connectivity Technology
- Radio
- Max Operating Distance
- 27 m
- Battery
- 2 AAA type
- 2-year warranty
- 3.1 cm
- 13.4 cm
- 6.6 cm
- 120 g
- Radio
- 27 m
- Built-in laser pointer, built-in receiver dongle storage
- Connector Type
- 1 x USB (4 PIN USB Type A)
- Operating System
- Apple Mac OS, MS Windows
- Included Accessories
- Storage case, USB receiver, 2 AAA batteries
- FCC, RoHS, WEEE
- 5 °C
- 45 °C
- 30 - 80%
- Battery
- 2 AAA type
- Limited warranty - 2 years
StarTech.com Wireless Presentation Remote | In Stock | £26.43 |
StarTech.com Wireless Presentation Remote w/ Green Laser Pointer - 90’ | In Stock | £35.23 |
