StarTech.com Wireless HDMI Transmitter and Receiver Kit
Quicklinx: FSJ1WS00 Mfr#: ST121WHDLR
£268.03 ex VAT
£321.63 inc VAT
This long-range Wireless HDMI Transmitter and Receiver Kit lets you transmit the audio/video signal from an HDMI source to a remote display up to 656 ft. (200 m) away.
This HDMI over wireless extender offers a practical and convenient alternative to traditional video cabling, which eliminates the cost of installing an expensive wiring infrastructure. This bundled kit includes both the transmitter and receiver, helping you avoid the expense of buying multiple devices to accomplish one task.
This wireless extender kit uses Wi-Fi to transmit a high-definition 1080p HDMI signal, as well as an IR signal for controlling your source device remotely.
With this wireless video extender, you can extend or mirror your device to share documents or multimedia content from anywhere in the room, making it the perfect solution for sharing ideas with your colleagues. It's also great for digital signage applications because it enables you to install your display wherever you'd like, unlike wired solutions that force you to compromise on location.
The HDMI video transmitter and receiver are very easy to install and use. With simple plug-and-play installation, setup is easy and hassle-free. The extender is a pure hardware solution that doesn't require any software or drivers, so you can avoid complicated software installation and configuration.
StarTech.com Wireless HDMI Transmitter and Receiver Kit - 656 ft. - 1080p (ST121WHDLR) - wireless video/audio extender
Wireless video/audio extender
External
Max Transfer Distance
200 m
External
Wireless
Max Resolution
1080p
200 m
Status Indicators
LAN, video
LPCM 7.1 support
1 x HDMI - 19 pin HDMI Type A female , 1 x IR female , 1 x mini-USB - Type A female
External power adapter
FSJ1 StarTech.com DC Power Adapter - 5V, 3A In Stock £11.95
