StarTech.com WiFi to HDMI Video Wireless Extender with Audio - High-Definition
Quicklinx: 8VTZWS00 Mfr#: WIFI2HD2
£84.63 ex VAT
£101.55 inc VAT
Wirelessly connect your PC or laptop to your HDMI television, projector, or monitor through your WiFi network. The WIFI2HD2 HDMI over Wi-Fi Adapter enables you to send an HDMI audio/video signal from a laptop or desktop computer, to a remote projector or display over a wireless IP network.
Unlike other wireless video solutions which require devices at both ends of the connection, the WIFI2HD2 is a single compact device that can be situated by your remote display, saving the hassle of carrying a secondary device, making it perfect for business applications such as boardroom presentations and data sharing. The only requirement is the included software must be installed on a computer to connect to the WIFI2HD2.
Compatible with Wireless-N (IEEE 802.11n) and backward compatible with Wireless-G (802.11 g) networks, this HDMI over WiFi extender supports data rates up to 150 Mbps, and supports resolutions up to 1080p for optimum video and audio quality. The extender also features an integrated USB port, for keyboard/mouse connection.
StarTech.com WiFi to HDMI Video Wireless Extender with Audio - HD - wireless video/audio extender - 802.11b/g, 802.11n (draft 3.0)
Wireless video/audio extender
External
Max Transfer Distance
55 m
AC 100/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
2.7 cm x 7.1 cm x 2.7 cm
140 g
External
Wireless
Max Resolution
1920 x 1080 / 1080p
55 m
1 x HDMI , 1 x network - RJ-45
FCC, RoHS
External power adapter
AC 100/230 V
2.7 cm
7.1 cm
2.7 cm
140 g
8VTZ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.52
8VTZ StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
8VTZ StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £6.03
8VTZ StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
8VTZ StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.99
8VTZ StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £8.65
8VTZ StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £17.91
8VTZ StarTech.com DC Power Adapter - 5V, 3A In Stock £11.71
