Wirelessly connect your PC or laptop to your HDMI television, projector, or monitor through your WiFi network. The WIFI2HD2 HDMI over Wi-Fi Adapter enables you to send an HDMI audio/video signal from a laptop or desktop computer, to a remote projector or display over a wireless IP network.
Unlike other wireless video solutions which require devices at both ends of the connection, the WIFI2HD2 is a single compact device that can be situated by your remote display, saving the hassle of carrying a secondary device, making it perfect for business applications such as boardroom presentations and data sharing. The only requirement is the included software must be installed on a computer to connect to the WIFI2HD2.
Compatible with Wireless-N (IEEE 802.11n) and backward compatible with Wireless-G (802.11 g) networks, this HDMI over WiFi extender supports data rates up to 150 Mbps, and supports resolutions up to 1080p for optimum video and audio quality. The extender also features an integrated USB port, for keyboard/mouse connection.
- StarTech.com WiFi to HDMI Video Wireless Extender with Audio - HD - wireless video/audio extender - 802.11b/g, 802.11n (draft 3.0)
- Wireless video/audio extender
- Form Factor
- External
- Data Link Protocol
- Max Transfer Distance
- 55 m
- Power
- AC 100/230 V
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 2.7 cm x 7.1 cm x 2.7 cm
- 140 g
- 2-year warranty
- Form Factor
- External
- Connectivity Technology
- Wireless
- Max Resolution
- 1920 x 1080 / 1080p
- 55 m
- 1 x HDMI , 1 x network - RJ-45
- FCC, RoHS
- Power Device
- External power adapter
- Voltage Required
- AC 100/230 V
- OS Required
- 2.7 cm
- 7.1 cm
- 2.7 cm
- 140 g
- Limited warranty - 2 years
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.80 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £4.94 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.74 |
StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £14.74 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.01 |
