The StarTech.com Wi-Fi 6E USB Adapter/Dongle enhances wireless connectivity for desktop and laptop PCs. This adapter supports a wide spectrum of Wi-Fi protocols from 802.11 b/g/n/ac/ax and introduces compatibility with the 6 GHz band, offering less interference and fast speeds. With a maximum data rate of 2402 Mbps on both 5 and 6 GHz bands, and 574 Mbps on the 2.4 GHz band, it's designed to meet the demands of bandwidth-intensive applications without compromising on speed or reliability.
Featuring a foldable antenna and a convenient USB extension cable, it provides flexibility in placement for optimal signal reception. The adapter is also equipped with MU-MIMO technology, ensuring efficient bandwidth use and a stable connection for simultaneous data streams. Security is a priority, with support for encryption standards including WPA3-Personal and WPA3-Enterprise, safeguarding your network against unauthorized access. Whether for work or play, the StarTech.com Wi-Fi 6E USB Adapter offers a powerful, secure, and easy-to-install solution for upgrading your wireless connectivity.
Enhanced connectivity
The Wi-Fi 6E USB Adapter by StarTech.com ensures your desktop or laptop achieves fast speeds with Wi-Fi 6E technology, supporting 2.4, 5, and 6 GHz networks for versatile and rapid connectivity. -
Robust security
Equipped with encryption algorithms including AES, WPA3-Personal, and WPA3-Enterprise, this adapter provides a secure connection to protect against unauthorized access and ensure your data remains safe. -
High-speed performance
With a data transfer rate of up to 5400 Mbps and features like MU-MIMO technology and full duplex mode, this adapter delivers speed and efficiency for streaming, gaming, and downloads without lag. -
Flexible installation
The foldable antenna and included 1.1 m USB extension cable offer versatile placement options to optimize signal strength and performance, while its compact, bus-powered design allows for easy portability and use on-the-go.
- StarTech.com Wi-Fi 6E USB Adapter/Dongle, For Desktop/Laptop PC, Wireless NIC w/Foldable Antenna, WiFi Adapter Supports 802.11 b/g/n/ac/ax, 2.4/5/6 GHz Network Compatible - network adapter - USB 3.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- 3.7 cm x 9.4 cm x 1.6 cm
- 32 g
- Data Link Protocol
- Wi-Fi 5, Wi-Fi 6E
- Data Transfer Rate
- 5400 Mbps
- Performance
- Maximum data rate (6 GHz): 2402 Mbps , Maximum data rate (5 GHz): 2402 Mbps , Maximum data rate (2.4 GHz): 574 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz, 6 GHz
- Processor
- 1 x Realtek Semiconductor RTL8832CU
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, USB 3.2 Gen 1, Wi-Fi CERTIFIED 6E
- Black
- System Requirements
- Microsoft Windows 10 / 11
- 2-year warranty
- Network adapter
- Form Factor
- External
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E)
- Spread Spectrum Method
- OFDMA
- 5400 Mbps
- Performance
- Line Coding Format
- DBPSK, DQPSK, CCK, 256 QAM, OFDM, 1024 QAM, OFDMA
- Frequency Band
- Status Indicators
- Power, link/activity
- Full duplex mode, plastic housing, MU-MIMO technology, promiscuous mode, bus powered, foldable aerial
Aerial
- Antenna
- External
- Antenna Qty
- 1
Processor / Memory
- Processor
- Included Accessories
- USB cradle
- Cables Included
- 1 x USB extension cable (integrated) - 1.1 m
- Encryption Algorithm
- AES, WPA, WPA2, WPA2-PSK, WEP, WPS, WPA3-Enterprise, WPA3-Personal
- RoHS, WEEE
- Black
- OS Required
- 3.7 cm
- 9.4 cm
- 1.6 cm
- 32 g
- Shipping Width
- 14 cm
- Shipping Depth
- 16.9 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 284 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95% RH (non-condensing)
StarTech.com 4 Port USB 3.0 Hub USB-C to 4x USB-A | In Stock | £30.59 |
StarTech.com 4-Port USB Hub 5Gbps, Portable | In Stock | £25.88 |
