StarTech.com WiFi 6E USB Adapter/Dongle
Quicklinx: HSVQWS00 Mfr#: AX54005A-USB-WIFI-6E
  • IEEE 802.11n
£66.66 ex VAT
£79.99 inc VAT
The StarTech.com Wi-Fi 6E USB Adapter/Dongle enhances wireless connectivity for desktop and laptop PCs. This adapter supports a wide spectrum of Wi-Fi protocols from 802.11 b/g/n/ac/ax and introduces compatibility with the 6 GHz band, offering less interference and fast speeds. With a maximum data rate of 2402 Mbps on both 5 and 6 GHz bands, and 574 Mbps on the 2.4 GHz band, it's designed to meet the demands of bandwidth-intensive applications without compromising on speed or reliability.
Featuring a foldable antenna and a convenient USB extension cable, it provides flexibility in placement for optimal signal reception. The adapter is also equipped with MU-MIMO technology, ensuring efficient bandwidth use and a stable connection for simultaneous data streams. Security is a priority, with support for encryption standards including WPA3-Personal and WPA3-Enterprise, safeguarding your network against unauthorized access. Whether for work or play, the StarTech.com Wi-Fi 6E USB Adapter offers a powerful, secure, and easy-to-install solution for upgrading your wireless connectivity.
  • Enhanced connectivity
    The Wi-Fi 6E USB Adapter by StarTech.com ensures your desktop or laptop achieves fast speeds with Wi-Fi 6E technology, supporting 2.4, 5, and 6 GHz networks for versatile and rapid connectivity.
  • Robust security
    Equipped with encryption algorithms including AES, WPA3-Personal, and WPA3-Enterprise, this adapter provides a secure connection to protect against unauthorized access and ensure your data remains safe.
  • High-speed performance
    With a data transfer rate of up to 5400 Mbps and features like MU-MIMO technology and full duplex mode, this adapter delivers speed and efficiency for streaming, gaming, and downloads without lag.
  • Flexible installation
    The foldable antenna and included 1.1 m USB extension cable offer versatile placement options to optimize signal strength and performance, while its compact, bus-powered design allows for easy portability and use on-the-go.
StarTech.com Wi-Fi 6E USB Adapter/Dongle, For Desktop/Laptop PC, Wireless NIC w/Foldable Antenna, WiFi Adapter Supports 802.11 b/g/n/ac/ax, 2.4/5/6 GHz Network Compatible - network adapter - USB 3.0
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
3.7 cm x 9.4 cm x 1.6 cm
32 g
Wi-Fi 5, Wi-Fi 6E
Data Transfer Rate
5400 Mbps
Performance
Maximum data rate (6 GHz): 2402 Mbps , Maximum data rate (5 GHz): 2402 Mbps , Maximum data rate (2.4 GHz): 574 Mbps
Frequency Band
2.4 GHz, 5 GHz, 6 GHz
1 x Realtek Semiconductor RTL8832CU
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, USB 3.2 Gen 1, Wi-Fi CERTIFIED 6E
Microsoft Windows 10 / 11
Network adapter
External
SuperSpeed USB 3.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6E)
Spread Spectrum Method
OFDMA
Data Transfer Rate
5400 Mbps
Performance
Line Coding Format
DBPSK, DQPSK, CCK, 256 QAM, OFDM, 1024 QAM, OFDMA
Frequency Band
Status Indicators
Power, link/activity
Full duplex mode, plastic housing, MU-MIMO technology, promiscuous mode, bus powered, foldable aerial
Aerial
Antenna
External
Antenna Qty
1
Processor / Memory
USB cradle
1 x USB extension cable (integrated) - 1.1 m
Encryption Algorithm
AES, WPA, WPA2, WPA2-PSK, WEP, WPS, WPA3-Enterprise, WPA3-Personal
RoHS, WEEE
3.7 cm
9.4 cm
1.6 cm
32 g
Shipping Width
14 cm
Shipping Depth
16.9 cm
Shipping Height
4 cm
Shipping Weight
284 g
5 - 95% RH (non-condensing)
