Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTW White Lightning-to-Micro USB dongle adapter for iPhone, iPod, iPad enables you to sync and charge your Apple Lightning devices using a Micro USB cable.
Perfect for people on the go, the adapter allows you to use your existing Micro USB cable as a Lightning cable, saving you from having to carry multiple cables for your various mobile devices.
The dongle offers approximately 4-inches in cable length and provides a lightweight, portable design that fits nicely inside your laptop carrying case. Plus, the dongle lessens strain on the connector port and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
This durable adapter is Apple MFi certified.
- Startech White Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad - Apple Lightning to Micro USB 2.0 Dongle (USBUBLTW) - Lightning adapter - Lightning / USB - 10.15 cm
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28/32
- Cable Length
- 10.15 cm
- White
- Connector
- Lightning - male
- Connector (Second End)
- Micro-USB Type B - female
- 2-year warranty
- Cable Type
- Lightning adapter
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 24/28/32
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Cable Length
- 10.15 cm
- White
- Connector
- Apple Lightning - male
- 5 pin Micro-USB Type B - female
- RoHS
- Limited warranty - 2 years
