StarTech.com Wall Mounted Workstation - Extendable Dual Monitor Arm
Quicklinx: FC04WS00 Mfr#: WALLSTSI2
Accessory Type: Mount
£635.13 ex VAT
£762.15 inc VAT
Increase your productivity, with a workstation that fits the way you work. Designed for a wide range of motion, this dual monitor wall-mounted computer workstation is easily adjustable with independent arms for your monitor and keyboard.
Move the wall-mounted sit-stand desk into position to work. Then push it back against the wall when not in use, folding the arms close to the wall. It's perfect for use in hospitals, clinics, warehouses, and other space-limited areas.
Extend the articulating monitor arms up to 25.6" (65 cm) from the wall. For ideal positioning, you can tilt or swivel your monitors, or rotate 360 degrees. The dual-monitor sit-stand workstation supports two VESA mount (75x75, 100x100) monitors up to 30", with a maximum weight of 19.8 lb. (9 kg) per display.
This wall-mounted height-adjustable desk enables a wide range of users to work in comfort. Adjust the height of both arms along the pole up to 17.5" (44.5 cm), plus the spring monitor arm has a height adjustment range of 10.6" (27 cm).
Place your keyboard where you need it, with an independent keyboard tray that extends up to 30.9" (78.4 cm) from the wall. Tilt the keyboard back to make sure your wrists are in a neutral position while typing. Place your mouse in the holder when not in use.
The modular design, with quick slide-and-click connections, makes installation easy and saves time when setting up multiple units.
StarTech.com Wall Mount Workstation, Articulating Standing Desk w/ Ergonomic Height Adjustable Dual Monitor Arm & Keyboard Tray, 2x 30" VESA Displays, Foldable Wall Mounted Sit Stand Desk - Foldable Standing Desk (WALLSTSI2) mounting kit - for 2 LCD displays / keyboard / mouse - silver - TAA Compliant
Mounting kit - wall-mountable
Mounting Components
Pole, mouse holder, wrist rest, wall mount bracket, keyboard tray, 2 display brackets, 2 x spring arms, 2 x swivel arms with logo, monitor shoulder, wall mount bracket with lock plate, 2 x swivel arms, mouse tray, mouse tray fixed plate, EVA mouse pad
72.2 cm x 74.2 cm x 123 cm
Tilt
-15° to 90°
Pan
-120° to 120°
Rotation
360°
Adjustments
14.2 kg
Recommended Use
Recommended Display Size
13"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
20.5 kg
Material
Plastic, aluminium, steel
Silver
TAA Compliant
72.2 cm
74.2 cm
123 cm
14.2 kg
Material
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
13"-30"
Tilt
-15° to 90°
Pan
-120° to 120°
Rotation
360°
Adjustments
Max Load Weight
20.5 kg
TAA Compliant
Dimensions & Weight Details
Dimensions
Keyboard tray - width: 68.3 cm, depth: 25.8 cm
95 cm x 14 cm x 59 cm / 14.4 kg
FC04 StarTech.com Wall Mounted Sit Stand Desk In Stock £330.59
FC04 StarTech.com Wall Mounted Computer Workstation - Extendable Monitor Arm In Stock £359.28
Price Range Ex VAT: £500 - £750
