StarTech.com Wall Mounted Computer Workstation - Extendable Monitor Arm
Quicklinx: FC0JWS00 Mfr#: WALLSTSI1
£364.06 ex VAT
£436.87 inc VAT
Increase your productivity, with a workstation that fits the way you work. Designed for a wide range of motion, this wall-mounted computer workstation is easily adjustable with independent arms for your monitor and keyboard.
Move the wall-mounted sit-stand desk into position to work. Then push it back against the wall when not in use, folding the arms close to the wall. It's perfect for use in hospitals, clinics, warehouses, and other space-limited areas.
Extend the articulating monitor arm up to 25.6" (65 cm) from the wall. For ideal positioning, tilt or swivel your monitor, or rotate 360 degrees. The sit-stand workstation supports a VESA mount (75x75, 100x100) monitor up to 30", with a maximum weight of 19.8 lb. (9 kg).
This wall-mounted height-adjustable desk enables a wide range of users to work in comfort. Adjust the height of both arms along the pole up to 17.5" (44.5 cm), plus the spring monitor arm has a height adjustment range of 10.6" (27 cm).
Place your keyboard where you need it, with an independent keyboard tray that extends up to 30.9" (78.4 cm) from the wall. Tilt the keyboard back to make sure your wrists are in a neutral position while typing. Place your mouse in the holder when not in use.
The modular design, with quick slide-and-click connections, makes installation easy and saves time when setting up multiple units.
  • Free Up Space
  • Optimum Viewing
  • Convenient Height Adjustment
  • Adjustable Keyboard Tray
  • Easy Installation
    The modular design, with quick slide-and-click connections, makes installation easy and saves time when setting up multiple units. The TAA compliant WALLSTSI1 is backed by a StarTech.com 10-year warranty and free lifetime technical support.
StarTech.com Wall Mount Workstation, Articulating Standing Desk w/ Ergonomic Height Adjustable Monitor Arm & Padded Keyboard Tray, 34" VESA Display, Foldable Wall Mounted Sit Stand Desk - Foldable Standing Desk (WALLSTSI1) mounting kit - for LCD display / keyboard / mouse - silver - TAA Compliant
Mounting kit - wall-mountable
Mounting Components
Pole, mouse holder, wrist rest, spring arm, wall mount bracket, keyboard tray, monitor mount, wall mount bracket with lock plate, swivel arm with logo, 2 x swivel arms, mouse tray, mouse tray fixed plate, EVA mouse pad
68.3 cm x 74.2 cm x 123 cm
Tilt
-15° to 90°
Pan
-120° to 120°
Rotation
360°
Adjustments
11.2 kg
Recommended Use
Recommended Display Size
13"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
11.5 kg
Material
Plastic, aluminium, steel
Silver
TAA Compliant
68.3 cm
74.2 cm
123 cm
11.2 kg
Material
Silver
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
13"-30"
Tilt
-15° to 90°
Pan
-120° to 120°
Rotation
360°
Adjustments
Max Load Weight
11.5 kg
TAA Compliant
Dimensions & Weight Details
Dimensions
Keyboard tray - width: 68.3 cm, depth: 25.8 cm
95 cm x 14 cm x 59 cm / 11.4 kg
FC0J StarTech.com Wall Mounted Sit Stand Desk In Stock £334.68
