StarTech.com Wall Mount Monitor Arm-10.2" Swivel Arm up to 30" Monitors
Quicklinx: FF5CWS00 Mfr#: ARMWALLDS2
Accessory Type: Mount
Hurry, only 2 left in stock!
£61.04 ex VAT
£73.24 inc VAT
Free up space with this wall-mount monitor arm and enjoy optimum viewing with the swiveling extension arm. The premium design ensures smooth, effortless motion and makes it easy to re-position your display, to work in comfort or collaborate with others. The attractive silver finish complements your decor.
The wall-mount system is ideal for business, healthcare, financial or other settings, where you may want to share your screen, or for customer-facing interactive displays.
The wall-mount monitor arm extends 10.2" (26 cm), making it easy to change your screen position. Move the swivel wall-mount freely, to the left or right. You can also adjust the swivel tension.
The robust aluminum design provides a stable wall-mount for your computer monitor or flat-screen TV up to 30". It's ideal for touch-screen stability. The universal display wall mount supports VESA mount monitors (75x75, 100x100) up to 30.9 lb. (14 kg) in weight.
Share your screen with ease. The display wall mount offers a full +180-degree/-180-degree pan, to move your screen left or right. It tilts freely +90/-15-degrees, to adjust the angle up or down. Rotate your screen for landscape or portrait viewing.
Push the swivel arm back to the wall, so your monitor sits just 5" (129 mm) from the wall when not in use.
The quick slide-and-click connections make the monitor wall mount easy to assemble and saves time when setting up multiple units.
StarTech.com Wall Mount Monitor Arm - 10.2" Swivel Arm - For up to 34" VESA bracket - adjustable arm - for LCD display - silver
Bracket (adjustable arm) - wall-mountable
Adjustable Depth
Up to 26 cm
Tilt
-15° to 90°
Pan
-180° to 180°
Rotation
360°
Adjustments
Pan, tilt, swivel
Recommended Use
LCD display
Recommended Display Size
13"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
14 kg
Material
Aluminium
Silver
Package Content
Hex key, 4 x thumbscrews, 2 x mounting screws, 2 x wall plugs, swivel arm
Adjustable Depth
Up to 26 cm
Material
Aluminium
Silver
Package Content
AV Furniture
Bracket
Design
Adjustable arm
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
13"-30"
Tilt
-15° to 90°
Pan
-180° to 180°
Rotation
360°
Adjustments
Pan, tilt, swivel
Max Load Weight
14 kg
Dimensions & Weight Details
13.9 cm x 17.8 cm x 33.9 cm / 1.4 kg
FF5C StarTech.com Thin Client Mount - VESA In Stock £22.13
FF5C StarTech.com Wall Mount Monitor Arm-10.2" Swivel Arm up to 30" Monitors In Stock £61.04
FF5C StarTech.com Wall Mount Monitor Arm-20.4" Swivel Arm up to 30" Monitors In Stock £81.32
FF5C StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
FF5C StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
FF5C StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
