StarTech.com Wall Mount Dual Monitor Arm
Quicklinx: D4FDWS00 Mfr#: ARMDUALWALL
Accessory Type: Mount
10 In Stock
£83.99 ex VAT
£100.78 inc VAT
Save space by mounting two monitors on your wall. This dual-monitor wall mount frees up space and creates a professional looking multi-monitor setup. Your two monitors move together to stay aligned. Simply extend the arm to place your monitors in the ideal position, or tuck them close to the wall when not in use. Plus, you can tilt, swivel and rotate your screens for optimal viewing.
The dual-monitor wall mount makes it easy to set-up two monitors in a business, commercial or office environment such as a health care or financial center. Both monitors are mounted on a single arm, so they move together in perfect unison, staying aligned at all times.
Using the mounting arm, you can extend your monitors up to 23" (585 mm) from the wall, so you can place your monitors for comfortable viewing. The arm also folds back in, so your monitors can be tucked just 6.5" (165 mm) from the wall when not in use, for a professional low-profile look.
Change the position and angle of your screens for ideal viewing. You can swivel your monitors up to 180°, and rotate up to 360° for landscape or portrait viewing. You can also tilt your monitors -15° to +15° to reduce glare and ensure a comfortable viewing position.
Made of steel, the dual-monitor wall mount securely supports two monitors, with a weight capacity of 11 lb. (5 kg) per monitor. It provides a stable setup for monitors up to 24".
StarTech.com Wall Mount Dual Monitor Arm, Articulating Ergonomic VESA Wall Mount for 2x 24" Displays, Synchronized Adjustable Crossbar, Tilt/Swivel/Rotate, Double Screen Mount Bracket - Multi Monitor Wall Mount (ARMDUALWALL) bracket - adjustable arm - for 2 monitors
Bracket (adjustable arm) - wall-mountable
7 cm x 64 cm x 18.35 cm
Tilt
-15° to 15°
Pan
180°
Rotation
360°
Adjustments
Tilt, swivel, rotation
Recommended Use
2 monitors
Recommended Display Size
15"-24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Material
Heavy duty steel
Package Content
Crossbar, 2 x VESA monitor mounts, 8 x M4x12 screws, 8 x M4x30 screws, 4 x washers, 4 x concrete anchors, 8 x spacers, hex key, 2 x plastic covers, 2 x cable-management clips, wall plate, 2 x mounting arms, crossbar cap, mounting arm retainer, 3 x M8x16 screws, 3 x mounting-arm washers, 2 x mounting-arm caps, wall plate retainer, level, 4 x M8x60 screws, crossbar retainer
5-year warranty
7 cm
64 cm
18.35 cm
Material
Heavy duty steel
Package Content
AV Furniture
Bracket
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Wall-mountable
15"-24"
Tilt
-15° to 15°
Pan
180°
Rotation
360°
Adjustments
Max Load Weight
10 kg
Limited warranty - 5 years
D4FD StarTech.com Thin Client Mount - VESA In Stock £22.13
D4FD StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
D4FD StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
D4FD StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
D4FD StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.34
D4FD StarTech.com Six-Monitor Desk Mount/Max 32" In Stock £270.47
