StarTech.com Wall Mount Arm - Single Swivel
Quicklinx: CRYHWS00 Mfr#: ARMWALLS
Accessory Type: Mount
19 In Stock
£22.15 ex VAT
£26.58 inc VAT
Save space by wall-mounting your monitor, and work more comfortably with the adjustable swivel mount. Wall-mount your computer monitor or flat-screen TV to free up space on your desk or table. This wall-mount monitor arm supports flat-panel displays up to 27" and provides 7.7" (195 mm) arm extension allowing versatile screen adjustment. The pivoting arm swivels +90° / - 90°and tilts to provide maximum viewing flexibility.
This monitor arm helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. (15kg) in weight. It's ideal for many different applications, including business, healthcare or financial settings, where you may want to share your screen with patients, clients, or other visitors. The wall-mount monitor arm also works well in office settings or workspaces that back against a wall.
The monitor arm extends 7.7" (195 mm), making it easy to change your screen position, so you can work more comfortably or share your screen with others. The adjustable single-swivel mount offers a full +90° / - 90° swivel, to move your screen easily to the left or right, to share your screen with maximum viewing flexibility. It tilts freely +45° / - 45°, allowing easy angle adjustment up or down to share your display, while collaborating with team members.
The aluminum wall-mount monitor arm features slide-in wall plate construction for easy installation. To help keep your work area free of clutter, the monitor arm also features a cable clip that keep your cables neatly out of sight.
  • Flexible positioning
    This monitor wall mount features an adjustable arm that allows users to tilt and pan for ideal viewing positions, suitable for varied workspace needs.
  • Sturdy construction
    Made of high-quality aluminum, this wall mount ensures strength and durability, supporting monitors securely with a maximum load weight of 15 kg.
  • Easy installation
    Equipped with necessary mounting components including screws and hex keys, installation is straightforward, providing quick setup for any user.
  • Space-saving design
    The compact profile of this monitor mount helps maximize desk space, making it a choice for home offices or professional environments.
StarTech.com Monitor Wall Mount - Single Swivel - Supports Monitors 13" to 34" - VESA Monitor Wall Mount Bracket - Black (ARMWALLS) adjustable arm - for monitor / flat panel - black
Adjustable arm
Mounting Components
Mounting plate
15.4 cm x 19.5 cm x 11.9 cm
Tilt
-45° to 45°
Pan
-90° to 90°
Adjustments
Swivel
Recommended Use
Monitor / flat panel
Recommended Display Size
13"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
15 kg
Material
Aluminium
Package Content
4 x M5x14 screws, hex key (4mm), hex key (5mm), hex key (2.5mm), 4 x M4x14 screws, 2 x screws, 2 x wall screws
5-year warranty
15.4 cm
19.5 cm
11.9 cm
Material
Aluminium
Package Content
AV Furniture
Adjustable arm
Mounting Components
Mounting plate
Recommended Use
13"-34"
Tilt
-45° to 45°
Pan
-90° to 90°
Adjustments
Swivel
Max Load Weight
15 kg
Limited warranty - 5 years
CRYH StarTech.com Monitor Wall Mount - Aluminum In Stock £16.86
CRYH StarTech.com Wall Mount Arm - Single Swivel In Stock £22.15
CRYH StarTech.com Wall Mount Arm - Dual Swivel In Stock £31.27
CRYH StarTech.com Thin Client Mount - VESA In Stock £23.04
CRYH StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
CRYH StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
CRYH StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £78.75
